dongju.jeong Posted January 30, 2020 Share Posted January 30, 2020 in IG_Template, Is IMeteo managed by ig_manager automatically processed by receiving wheather control packet? And also inside the Unigine code, does the environment change when IMeteo's functions are used directly? Unigine's IG cannot handle environment region packets automatically. How can I use IRegion managed by IMeteo? Link to comment
cash-metall Posted January 30, 2020 Share Posted January 30, 2020 Meteo and Region automaticly processed by weather control packet. also Meteo and Regions can also be controlled manually. in enviroment_control not supported: Merge Weather Properties Merge Aerosol Concentrations Merge Maritime Surface Conditions Merge Terrestrial Surface Conditions Corner Radius Transition Perimeter but position, size, id is supported and work via CIGI_ICD region parameters can also be set via weather_control packet 1 Link to comment
dongju.jeong Posted January 30, 2020 Author Share Posted January 30, 2020 thank you. If I set weather control's scope 1 and sand packet, Is it possible to make a small amount of clouds, snow or rain in a specific area? Link to comment
cash-metall Posted January 30, 2020 Share Posted January 30, 2020 snow and rain - yes clouds - no. clouds are possible only globally. we are working on regional clouds 1 Link to comment
