Amerio.Stephane Posted January 23, 2020 Share Posted January 23, 2020 Hello, In a dual screen configuration, if the SDK browser is on the main screen and the screen is disconnected (or turned off), then the SDK Browser crashes or closes itself instead on going to the second screen. This is especially problematic when working with a KVM and switching between two computers, because it keeps crashing and the Editor will complain and closes itself. This actually prevents us from working on two workstation at once with a KVM. Thank you Link to comment
silent Posted January 23, 2020 Share Posted January 23, 2020 Hi Stephane, Both Linux and Windows versions affected? Which one is more critical to fix? How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
Amerio.Stephane Posted January 23, 2020 Author Share Posted January 23, 2020 Tested on Windows. No issue on Linux for us at the moment as our Linux doesn't cut the display off behind the KVM. But the pb may still exists, I just can't test it right now. Link to comment
silent Posted January 24, 2020 Share Posted January 24, 2020 Thanks for the additional information. We've successfully reproduced this behavior on Windows machines. Right now the only workaround possible is to manually move SDK Browser window to a secondary monitor (if it's working in extended mode). We will try to fix this prior to 2.11 SDK update. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
