CIGI issues with LOS Segment / Vector both requested
We noticed an issue with LOS Segment / Vector both requested with same params with src coord system CigiLosVectReqV3_2::Entity and checking 10m bellow the entity.
Separately, both work fine and answer valid offsets. Even intersection masks are fine ;)
But requested together -> Unhandled exception at 0x00007FFFCAA6B0BE (ucrtbase.dll) in cigi_2-9_x64d.exe: Fatal program exit requested.
In our host implementation, here are CIGI packet / version used:
  • LOS Segment request -> CigiLosSegReqV3_2
  • LOS Vector request -> CigiLosVectReqV3_2
It is reproduced with CIGI demo 2.9, only ig_config.xml updated.
Any clue?
Kind regards,
Charles
Related to this topic, are all object intersect validated?
For example ObjectWaterGlobal works fine, but ObjectWaterMesh not really, even with intersect mask set to all.
Hi Charles,
I assume you're using a custom CIGI Host application.
Can you send us a full Call Stack?
Last time I've tried this with WaterMesh it worked. Can you give some more info on the issue?
Thank you.
For the water I setup the world with default ground, add WaterMesh instead of WaterGlobal, setup intersect mask, and run it -> no intersection detected / sent to host.
Exactly the same world, but MeshStatic instead, with same intersect mask -> intersection detected / sent to host.
Regarding the LOS Segment / Vector issue, yes it is in-house CIGI host / wrapper or IG abstraction.
What is disturbing is that only segment request is fine, only vector as well, but both crash.
Pack LOS Segement request
CigiLosSegReqV3_2 req;
req.SetLosID( id );
req.SetReqType( CigiLosSegReqV3_2::Extended );
req.SetUpdatePeriod( los.update_period );
if ( los.source_point_coordinate_system ) {
	req.SetSrcCoordSys( CigiLosSegReqV3_2::Entity );
	req.SetEntityID( los.source_entity_id );
	req.SetSrcXoff( los.source_x_offset );
	req.SetSrcYoff( los.source_y_offset );
	req.SetSrcZoff( los.source_z_offset );
} else {
	req.SetSrcCoordSys( CigiLosSegReqV3_2::Geodetic );
	req.SetSrcLat( los.source_latitude  );
	req.SetSrcLon( los.source_longitude );
	req.SetSrcAlt( los.source_altitude  );
if ( los.destination_point_coordinate_system ) {
	req.SetDstCoordSys( CigiLosSegReqV3_2::Entity );
	req.SetDestEntityID(      los.destination_entity_id );
	req.SetDestEntityIDValid( los.destination_entity_id_valid );
	req.SetDstXoff( los.destination_x_offset );
	req.SetDstYoff( los.destination_y_offset );
	req.SetDstZoff( los.destination_z_offset );
} else {
	req.SetDstCoordSys( CigiLosSegReqV3_2::Geodetic );
	req.SetDstLat( los.destination_latitude  );
	req.SetDstLon( los.destination_longitude );
	req.SetDstAlt( los.destination_altitude  );
req.SetResponseCoordSys(
		los.response_coordinate_system ?
		CigiLosSegReqV3_2::Entity : CigiLosSegReqV3_2::Geodetic
req.SetAlphaThresh( los.alpha_threshold );
req.SetMask(        los.material_mask );
*outgoingMsg << req; //operator call pack
Pack LOS Vector request
CigiLosVectReqV3_2 req;
req.SetLosID( id );
req.SetReqType( CigiLosVectReqV3_2::Extended );
	req.SetSrcCoordSys( CigiLosVectReqV3_2::Entity );
	req.SetEntityID( los.entity_id );
} else {
	req.SetSrcCoordSys( CigiLosVectReqV3_2::Geodetic );
		CigiLosVectReqV3_2::Entity : CigiLosVectReqV3_2::Geodetic
req.SetVectAz(      los.azimuth );
req.SetVectEl(      los.elevation );
req.SetMinRange(    los.minimum_range );
req.SetMaxRange(    los.maximum_range );
Would you see anything wrong?
Kind regards,
Charles
Confirmed, Water Mesh has major intersection issue and HAT/HOT wouldn't work for this object. I'm afraid we have no time to fix it before stable 2.10. As a workaround I suggest adding the same Static Mesh as a separate object with disabled viewport mask. HAT/HOT request will return it's value.
As for the crash, we had caught something very similar once, but we can't reproduce it. Will continue to investigate. Call Stack from your side could be helpful.
Thanks.
  • 2 weeks later...
Hi, Charles
I could not reproduce this problem. not at 2.9 not at 2.10.
it seems like the problem is in something else....
can you try to test (on a clean IG without weather, without an entity) send only these two requests in one package?
