Coppel.Damien Posted December 3, 2019 Share Posted December 3, 2019 (edited) Hi everyone, I fond out in the editor that UNIGINE has multiple panorama modes, two of them simulating a fisheye with 180 degrees and 360 degrees FOV. Unfortunately, these two values seem to be the only FOV that are available in the engine. Is there any way to modify a panorama mode (programmatically or not) to get FOV values between 180 and 360 degrees ? I'm interested in simulating a fisheye camera with a 190° FOV. I'm aware that the fisheye effect in UNIGINE is a stitching of the feed of 4 different cameras so I'm guessing the answer, if there is one, won't be something trivial. Thank you. Edited December 3, 2019 by Coppel.Damien Link to comment
morbid Posted December 4, 2019 Share Posted December 4, 2019 Hello Damien, All panorama modes are built in the engine itself and you have no options to modify them. Byt there's a possible scenario for your case: Write your own App plugin that will create 4 viewports. Please note, that you can use only one App plugin at the same time. Modify panorama shader to bend the image for 190° FoV. Sources are here: <SDK>\data\core\shaders\panorama I have to warn you that this can bring a lot of coding and research. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
