meshcutter
It is very difficult to understand your post.
Can you be a bit more precise please.
b,w
btw. There is a 'Edit Post' possibility. So you can correct spelling. e.g. the topic title  ....
ok
I generated the terrain with landscape tools.The terrain   generate is 10km x 10km
Added mask , generated trees.
.but  The area of the tree is too large,
The terrain is only four trees..
I want to make the area of each tree smaller, the trees generated by a terrain, the area more.
You mean that your object stores only 4 models, but the size is too big, right?
Unfortunately, Landscape can't automatically optimize this. You have two options:
  1. Manually change Mask Image and resize it to desired area.
  2. Manually replace this clutter with another and draw a mask in the Unigine Editor.
Thank you.
In my project, all the trees are generated by landscape tools.  There are only four child nodes. The area is too large.
image.png.00345643c4bc98a7f4364818df370eb2.pngimage.png.e446e4933e1d44c33139570927b2d87f.png
2.71 demo has 16 and too small  755x755
and this demo It can't be opened.  very  need this demo very much.
Unigine's interaction with trees and grass is too complicated.   Writing some FPS games, such as shooting, is not very simple too
 have reminder settings for community replies? Connect to my email I'm usually busy with my work. I'm not always in the forum.
Clutter or Grass size is always calculated automatically and depends on two factors:
  1. Play Area size
  2. Mask density
In any case, you'll get as a result 4096 x 4096 raster mask for grass or clutter. The max size of the object = landcover density * 4096. This wouldn't affect anything in your scene.
Tank demo is available in 2.7.2.1 only. You can copy it via SDK Browser and manually upgrade to the 2.9.
Use "Notify me of replies" switch.
