kyle.hubbard Posted November 2, 2019 Share Posted November 2, 2019 hi unigine community in 3ds max we can lit scene with only one hdri in ue4 we can lit scene with only one hdri (sky light) how we can lit scene with hdri in unigine here is my artwork with 3dsmax and ue4 with simple hdri but i cant achieve good quality with unigine Link to comment
silent Posted November 4, 2019 Share Posted November 4, 2019 Hi Kyle, You can enable SSRTGI (as Bake lightning dialog is suggesting) to improve baking quality. We are working on lightmapper solution that will improve baking quality even more (more likely it will be added next year with 2.11 SDK update). If this doesn't help, please, send us your model - we can see what else we can suggest. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
kyle.hubbard Posted November 5, 2019 Author Share Posted November 5, 2019 thanks for your answer here is my model hope you help me with render setting to achieve good qualityhttps://www.dropbox.com/s/wwy00pxt9e3m1nn/Lightmass-UVless.fbx?dl=0 Link to comment
silent Posted November 6, 2019 Share Posted November 6, 2019 Hi Kyle, Thanks for the test scene. Voxel probe is baking only bounces (not a direct lightning) - that's the main current limitation that prevents you to get the desired picture quality. Also to bake lightning only from HDRI texture voxel probe resolution more likely will be not enough. Lightmap and the second UV channel is still required for that kind of task (lightmap baker hopefully will be added after 2.10 SDK update). So right now the approach would be the following: reduce voxel size as much as possible (to get the resolution as much as possible) enable SSRTGI and Bent Normal in settings This will result in longer baking times and higher VRAM consumption. However, to get the same picture quality a lightmaps required. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
kyle.hubbard Posted November 6, 2019 Author Share Posted November 6, 2019 Thanks for your answer I hope the bests for unigine development team Link to comment
