davide445 Posted September 23, 2019 Share Posted September 23, 2019 (edited) Using a Substance anodized aluminum mat, very simple world with just a plane with ground_gird material applied and my model. With high Roughness = 1 seems to me realistic in term of reflection color, with values around <.7 (more realistic in my opinion related to the real material of the building) seems reflect the far away dark part of the sky (.5 here) Tried to set the ground_grid material as Two sided thinking was transparent from behind, but no difference. What am I doing wrong? Edited September 24, 2019 by davide445 Link to comment
cryunreal Posted September 23, 2019 Share Posted September 23, 2019 Hi! You need yo use environment probe with baked reflections for this scene. Just place an environment probe, select it and press bake selected lights button in the bake lighting window. Right now there is only environment reflections in your scene. 1 Link to comment
davide445 Posted September 23, 2019 Author Share Posted September 23, 2019 (edited) Thanks but this seems to didn't change the situation. Or maybe I have the wrong expectations, and need to change something else? Roughness = 1 Roughness = 0.5 No probe, R = .5 (Btw if you are the one developing SSRTGI I was reading your article, and in fact discovered Unigine searching for a RTGI solution better than Unreal one in fact not RT except for the unfinished LPV, an more usable than CryEngine, so congratulations for your work!) Edited September 24, 2019 by davide445 Link to comment
cryunreal Posted September 24, 2019 Share Posted September 24, 2019 Thank you reading the article! =) Try to place this 3d model in the start world. Pay attention to settings of the LightEnvironmentProbe and try to copy them. Link to comment
silent Posted September 24, 2019 Share Posted September 24, 2019 Hi Davide, Are you using the latest 2.9.0.2 SDK? In default world template we've added an example of Environment probe usage, you can try to add your object to a newly created world and see the difference. In your case the Environment probe is just to small and it seems that you partially bake the internals of this building (that's why it looks so dark). Please, check the following tutorials on Lightning setup: https://developer.unigine.com/forum/topic/4819-unigine-editor-2-video-tutorials-lighting-12/ https://developer.unigine.com/forum/topic/4821-unigine-editor-2-video-tutorials-lighting-voxel-global-illumination-22/ You also can download Samples 2 demo from SDK Browser and check the example with Environment probes placement: SDK Browser -> Samples -> Demos -> Samples 2.9. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
davide445 Posted September 24, 2019 Author Share Posted September 24, 2019 I'm using 2.8.0.1 since we developed some components on that platform, can I import the example from 2.9 to 2.8? Just testing LightVoxelProbe, a heavy calculation, didn't see so much speedup increasing the voxel per frame, since my 1070 GPU was already at 92% at 10 voxel per frame there wasn't so much headroom I suppose? No way to use a secondary GPU to offload this computation? Link to comment
silent Posted September 24, 2019 Share Posted September 24, 2019 You can just check the parameters of default nodes in 2.9 world and copy them to your project in 2.8. Samples with Environment probes are also exists in 2.8 SDK and previous. Quote Just testing LightVoxelProbe, a heavy calculation, didn't see so much speedup increasing the voxel per frame, since my 1070 GPU was already at 92% at 10 voxel per frame there wasn't so much headroom I suppose? Voxels calculation speedup is only related to the internal volume, so maybe it's not your case. Quote No way to use a secondary GPU to offload this computation? I'm afraid, not. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
davide445 Posted September 24, 2019 Author Share Posted September 24, 2019 (edited) Ok this is LightEnvironmentProbe This is LightVoxelProbe Final result with R=.5 Better but still dark in my opinion. Bake with 1 Bounce, tried with 3 and nothing change. Both object and terrain are at 0,0,0. The fact the terrain it's just a plan with ground_grid applied will have any influence? Edited September 24, 2019 by davide445 Link to comment
silent Posted September 24, 2019 Share Posted September 24, 2019 Hi Davide, You are making the same mistake again :) You don't need to bake Voxel probe to get a reflections. All you need a single Environment Probe with inf radius baked without your builing. After adding a building into the Environment probe volume you will get reflections of checkerboard ground. Here is the Environment Probe settings (baked without building): You need to press Bake Selected Lights once to bake reflections to the cubemap. Here is the results after enabling this probe: 1 How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
davide445 Posted September 24, 2019 Author Share Posted September 24, 2019 Ahhh. Got it. As always, thanks. Link to comment
