[SOLVED] Load RAW DXT1 texture
I try to load a RAW texture that I have in DTX1 format. I don't found a way to load a RAW texture. I try to load as image but log an error loading
int format = ::Unigine::Image::FORMAT_DXT1;
::Unigine::ImagePtr image = ::Unigine::Image::create();
image->create2D(textureSize, textureSize, format);
const ::Unigine::Ptr<::Unigine::Blob> stream = ::Unigine::Blob::create();
stream->write(textureData, textureLen);        // textureData=RAW DTX1 Buffer, textureLen=size
image->load(stream->getStream());
/roberto
Edited by roberto.voxelfarm
Thank you Silent,
The error is
   "ImageFileDDS::read_header(): wrong magic 0x0"
I know that the texture not is a DDS image file, is just a RAW DXT1 buffer,  and for that is the error.
For sample Unity have this function that allow to load Raw texture
Texture2D texture = new Texture2D(textureSize, textureSize, format, hasMipmaps, linear);
texture.LoadRawTextureData(textureData);
Is any possibility to load a RAW texture here like unity do?. or convert this to DDS format directly from the buffer or the streaming.
best regards
/roberto
6.rawTex
Hello Roberto,
There is no built-in serialization/deserialization of raw formats in the engine. Consider using DDS.
To work with a raw format you could allocate image of certain size and format with create2D and then put data directly to allocated memory with memcpy(image.getPixels(), data, size).
Also to read from blob after write it should be reset to the beginning with blob->seekSet(0).
  • silent changed the title to [SOLVED] Load RAW DXT1 texture
  • 2 months later...
