[SOLVED] combining multiple mesh skinned animations in tracker
I'm trying to combine multiple mesh skinned animations on the tracker using the 'track' option... with no success so far.
My process is...
1. import 'animation1.fbx'
2. import 'animation2.fbx'
3. in Tracker>add parameter>node>object>meshskinned>animation>ok
4. select node>'animation1.fbx'>ok
5. save track as 'animation1.track and clear track
6. in Tracker>add parameter>node>object>meshskinned>animation>ok
7.  select node>'animation2.fbx'>ok
8.  save track as 'animation2.track and clear track
9. select animation1 node
10, add tracker 'track'
11. add keyframe. double click keyframe and add animation1.track. add time and weight keys
12. add second keyframe, double click and add animation2.track. add time and weight keys
I know I'm missing something! Can you tell me where I'm going wrong with these steps?
As I understand, you want to create a sequence of different animations for selected skinned mesh. Am I right?
If so, you have to do the following:
  1. Create separate track files with different animations.
  2. Create a new track file.
  3. Add "track" parameter and assign your animation tracks to the keyframes
  4. Set two keyframes for time. First = 0, the last = 1
  5. Set one keyframe for weight = 1. Make sure that the value was saved (type 1 and hit Enter button)
Here's a snapshot, hope this helps.
  • 3 weeks later...
  • morbid changed the title to [SOLVED] combining multiple mesh skinned animations in tracker
