[SOLVED] fbx import crash
Import of this fbx crashes Unigine 2.8.0.1 (and Unigine keeps crashing just after start, if it is not deleted). It was created by export from Unigine, imported in 3dsmax 2015 and exported again from 3dsmax as fbx without any modifications (default export settings).
test.7z
Edited by demostenes
Hello Demostenes,
I've successfully imported this file in a default 2.8.0.1 project.
Please, check your import parameters. Will resetting them to default help?
Thanks.
UPD
I've reproduced the crash with your model only if "Import Tangent Space" is set to enabled. Is this your case?
1 hour ago, morbid said:
Hello Demostenes,
Thanks.
UPD
I dont know, I was importing with default parametres and because of crash I am not able to verify what was there. But in log was some error about tangents.
  • 2 months later...
Hi demostenes,
We fixed the crash. It was caused by attempt to merge two different surfaces, one had tangents, and another didn't. Similar to the case with vertex color. This operation wouldn't be valid until your number of vertices equals to the number of tangents.
  • morbid changed the title to [SOLVED] fbx import crash
