Migration from 2.7.3 to 2.8.0 delete struct in property file
after migration project from 2.7.3 to 2.8.0 version of Unigine, migration script delete struct in property file.
Structure was define in items.prop and used in children, for example  weapons.prop.
Data was not deleted, only "type".
Thanks
Honya
Hello honya,
Thanks for the bug report. I've added this issue to our internal bug tracker with critical priority.
This bug was also present in SDK 2.7.3.1 and deleting will keep happening when re-importing mentioned props in 2.8.
It is possible to use manual workflow for such type of properties, where structs defined and used in different .props. Actually it is better to use state manual="1" when writing root props that define structure for whole hierarchy because if property is manual you can be sure that it won't be ever somehow affected or changed by engine, editor or migration.
