[SOLVED] maximum namespace is is 32767
If I run my program for long enough, I get:
NameSpace::NameSpace(): maximum namespace is is 32767
Expression::run_0(): bad expression
I tried having the expressions be class_manage()'ed, in the hopes that deleting them would recycle past used anonymous namespaces.
But, it continues to have the problem.
Michael Zhang
You have exceeded interpreter limit of namespace instances. I would guess there is some kind of object leakage in your code. You should post minimal test case for problem reproduction.
  • 2 weeks later...
There really seems to be a bug with deleting expression namespace instances. Right now our developers are head and ears in work implementing large coordinates support, but approximately in a week they will be able to check it.
Okay, I assume this is in response to the test case I sent by e-mail?
I am looking forward to the solution.
Thanks
  • 3 weeks later...
Thanks
Any update on this issue?
Not yet :( But new coordinates implementation is almost over, so your issue will be dealt with really soon.
Please make sure that it is fixed in the next release, it's very frustrating to not be able to run the program for an extended period of time before crash. Thank you.
  • 2 weeks later...
It turned out expressions can't be created and deleted every frame. They are intended to be created once, for example, on world load, rather than dynamically. It is not only the matter of namespace instances limit. The memory will eventually run out in any case as each time the space is allocated for newly added code. If you need to execute something this often, it is more rational to create a normal function instead.
I am using Expressions to execute member functions from C++. If I cannot use Expressions, how do you recommend I achieve this?
I do not wish to create a global function for each object/member combination I need to access from C++.
Our devs use the following approach:
// UnigineScript
executeMember (int instance, string method_name) {
  instance.call("method_name");
// C++
Unigine::Variable instance;
engine->runWorld("executeMember", instance, "method_name");
  • 1 year later...
