tolchinski.alexei Posted March 11, 2019 Share Posted March 11, 2019 Hello. Projected light don't see hills from TerrainGlobal. Also, I tried to use setForceIntersection(1), but i have got feelings, that TerrainGlobal use only visible intersection. Is it normal? Version 2.7.2 Link to comment
silent Posted March 12, 2019 Share Posted March 12, 2019 Alexei, If you will enable Cast Shadows for the Heights LOD 1 - will it help in your case? 17 hours ago, tolchinski.alexei said: Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
tolchinski.alexei Posted March 12, 2019 Author Share Posted March 12, 2019 No, it doesn't help me. Link to comment
morbid Posted March 12, 2019 Share Posted March 12, 2019 Hello Alexey, The problem is in the light parameters. Projected Light + custom shape wouldn't work correctly with big visibility distances and such FOV values (100.5 degrees in your case). May I ask you to explain, what you're trying to do? Is it a specific lamp or a projector you're reproducing? Thanks. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
tolchinski.alexei Posted March 12, 2019 Author Share Posted March 12, 2019 Hello. I tried to reduce light distance parametrs and reduce FOV, but result didn't change. I'm trying to use light projector with certain degree and it is very import for my task, that terrain global has got shadows from this light. Link to comment
morbid Posted March 12, 2019 Share Posted March 12, 2019 Can you send us a test scene? Also, on your picture light ray is completely cut with a terrain. Where do you expect to see a shadow? UPD Or the bright part of terrain on the left is lit with light? Sorry, it's a bit unclear on the picture. Thanks. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
morbid Posted March 12, 2019 Share Posted March 12, 2019 And another thing worth checking - shadow resolution. Try to increase it in the Projected Light parameters. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
tolchinski.alexei Posted March 12, 2019 Author Share Posted March 12, 2019 Sorry for delay. Bright part on the left is light on terrain, yes. I didn't write accurately, ray cut with terrain, not shadow must be on the left part. project.zip Link to comment
tolchinski.alexei Posted March 12, 2019 Author Share Posted March 12, 2019 Thanks for help, problem was with material of Terrain Global. It mustn't be have shadow offset 10.0, it must be near 1.0. Link to comment
morbid Posted March 12, 2019 Share Posted March 12, 2019 Okay, glad to hear you've solved this. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
