dongju.jeong Posted March 8, 2019 Share Posted March 8, 2019 (edited) I used the CigiHost we used. If the cigi connection was successful, unigine successfully received the igcontrol packet per frame, but unigine did not restart the world and only received igcontrol packet. usually What kind of mistakes cause the world doesn't restart? Hemu is normal in testing. I success to restart world. But still only the ig control packet is received. I'll solve this for myself. thank you Edited March 8, 2019 by dongju.jeong Link to comment
cash-metall Posted March 11, 2019 Share Posted March 11, 2019 some tips: - Specify the name of your .world in the ig_config.xml - Don`t preload the world manualy (remove "world_load" args from master and slaves) - HEMU sends ig_control at start. If you start the IG after running the HEMU, then you need to manually send ig_control (select the database again, or via the Actions -> Send Packet -> IG Control) 1 Link to comment
