The moment the callback function of property is called
when Callback type is the CALLBACK_PARAMETER_CHANGED, Is callbackbase2 only possible?
if callbackbase1 is possible, When is the callback function actually called? (property have multiple parameters and When I change multiple parameters)
ex) in some class update()
property->getParameterPtr("my_param1")->setValue(1);   //callback function is called?
property->getParameterPtr("my_param2")->setValue(2);
property->getParameterPtr("my_param3")->setValue(3);
Will the callback function run in another space after this code block is finished?
Hi dongju.jeong,
Yes, it is. The first argument is a PropertyPtr, the second is a "parameter id".
Callback will run in the main thread right after setValue(1) line.
Best regards,
Alexander
then.. what do I do when I try to call a one callback function by considering all the parameter changes that property has at once?
For example, you can call your own callback function in your code (don't use Property::addCallback() in this case):
on_parameter_changed(property); // something like this
