[SOLVED] AppWall GUI overlaps standard gui elements
I'm trying to create two-windowed application by using AppWall Plugin in c++ side. Both windows contain only GUI elements (i implement my methods in System logic).
1 - I get GuiPtr for each monitor.
	Interpreter *interpreter = (Interpreter*)Engine::get()->getSystemInterpreter();
 	Reflection PLUGIN_reflection(interpreter, Variable("engine.wall")); //make sure that you have AppWall loaded here
 	Variable res = PLUGIN_reflection.callExternFunction("getGui", Variable(0), Variable(0));
 	gui_lecture = res.getGui(interpreter);
 	res = PLUGIN_reflection.callExternFunction("getGui", Variable(1), Variable(0));
   	gui_editor = res.getGui(interpreter);
2 - I place widgets in appropriate GUI
This GUI overlaps standard GUI elements, such as ESC-menu, mouse cursor, console, etc, so i can't act with it.
What i'm doing wrong?
Thank you.
I trying to make kind of text editor module, it is nessesery to make it on monitor wall. Now i use only two monitors, but it should be 3.
On left monitor it should be menu, on the right - text, slideshows, etc, and some additional information on down.
Hi Ilya,
You can try to patch AppWall plugin (<SDK>/source/plugins/App/AppWall/D3D11AppWall.cpp or GLAppWall.cpp) and move render_gui(i) line before App::render(). Something like that:
Before:
	if (primary)
		App::render();
	render_gui(i);
After:
	render_gui(i);
	if (primary)
		App::render();
  • silent changed the title to [SOLVED] AppWall GUI overlaps standard gui elements
