d83v83_ Posted January 21, 2019 Share Posted January 21, 2019 The objective I want to achieve is rendering Point Cloud data. First, I try to use renderPoint3D(), it works great but can not handle huge data set. Therefore, I follow the Unigine Scripte Samples "samples/shaders/particles_00.cpp" and rewrite into c++ project. But nothing was in the screen. Any suggestion to modify my code? Thanks in advanced! Here is my code: ObjectDynamicPtr pod; int AppWorldLogic::init() { pod = ObjectDynamic::create(); pod->setName("POINTS"); pod->setMaterial("particles", "*"); pod->setSurfaceProperty("surface_base", "*"); pod->setSurfaceMode(ObjectDynamic::MODE_POINTS, 0); pod->setMaterialNodeType(Node::OBJECT_MESH_DYNAMIC); pod->setInstancing(0); ObjectDynamic::Attribute *attrib = new ObjectDynamic::Attribute; const ObjectDynamic::Attribute attributes2[] = { { 0, ObjectDynamic::TYPE_FLOAT, 3 } ,{ 12, ObjectDynamic::TYPE_FLOAT, 2 } }; pod->setVertexFormat(attributes2, 2); pod->addPoints(65536); for (int i = 0; i < pod->getNumIndices(); i++) { vec3 vertex = vec3(Game::get()->getRandomFloat(-128.0f, 128.0f), Game::get()->getRandomFloat(-128.0f, 128.0f), Game::get()->getRandomFloat(2.0f, 64.0f)); pod->addVertexFloat(0, vertex, 3); vec2 xy = vec2(Game::get()->getRandomFloat(0.2f, 0.8f), Game::get()->getRandomFloat(0.0f, 3.1415)); pod->setVertexFloat(1, vec4(xy,0,0),2); } pod->flushVertex(); BoundBox bb = BoundBox(vec3(-128, -128, 2), vec3(128, 128, 64)); pod->setBoundBox(bb); } Link to comment
silent Posted January 21, 2019 Share Posted January 21, 2019 d83v83 Could you please share the whole project to us (source + data directories content at least)? Right now it's hard to predict what is going on here. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
fox Posted January 21, 2019 Share Posted January 21, 2019 Hi d83v83, Try modifying your code in init() as follows: int AppWorldLogic::init() { pod = ObjectDynamic::create(); pod->setName("POINTS"); pod->setMaterial("particles", "*"); // <- this material, along with the shaders it uses, must be copied to your project's data folder pod->setSurfaceProperty("surface_base", "*"); pod->setSurfaceMode(ObjectDynamic::MODE_POINTS, 0); pod->setInstancing(0); ObjectDynamic::Attribute attributes[2] = { { 0, ObjectDynamic::TYPE_FLOAT, 3 }, { 12, ObjectDynamic::TYPE_FLOAT, 2 } }; pod->setVertexFormat(attributes, 2); pod->addPoints(65536); for (int i = 0; i < pod->getNumIndices(); i++) { vec3 vertex = vec3(Game::get()->getRandomFloat(-128.0f, 128.0f), Game::get()->getRandomFloat(-128.0f, 128.0f), Game::get()->getRandomFloat(2.0f, 64.0f)); pod->addVertexFloat(0, vertex, 3); vec2 xy = vec2(Game::get()->getRandomFloat(0.2f, 0.8f), Game::get()->getRandomFloat(0.0f, 3.1415)); pod->setVertexFloat(1, vec4(xy, 0, 0), 2); } BoundBox bb = BoundBox(vec3(-128, -128, 2), vec3(128, 128, 64)); pod->setBoundBox(bb); return 1; } And make sure you've copied the following folders from the samples/shaders/ folder to your project's data folder: shaders/particles shaders/materials Hope this helps! Thank you! Link to comment
d83v83_ Posted January 22, 2019 Author Share Posted January 22, 2019 Thanks for your help. I did copy this two folder, shaders and materials under samples/shaders/, into my project's data folder. Attachment is my (source + data folders). Render_Points.zip Link to comment
fox Posted January 22, 2019 Share Posted January 22, 2019 As I can see from your attached files, you did not try the code I posted above. Either try the code above, or try commenting the following line in your AppWorldLogic.cpp : //pod->setMaterialNodeType(Node::OBJECT_MESH_DYNAMIC); or replacing it with: pod->setMaterialNodeType(Node::OBJECT_DYNAMIC); This method actually enables a sort of filter to prevent assignment of inappropriate materials. The point is that the "particles" material you use can be assigned to OBJECT_DYNAMIC nodes only (see the shader tag below) <?xml version="1.0" encoding="utf-8"?> <base_material name="particles" editable="0" version="2.5.0.2"> <blend src="one" dest="one"/> <options depth_mask="0" cast_shadow="0" cast_world_shadow="0" transparent="2"/> <shader pass="ambient" node="object_dynamic" vertex="shaders/particles/vertex.shader" geometry="shaders/particles/geometry.shader" fragment="shaders/particles/fragment.shader"/> <texture name="diffuse" wrap="clamp">core/textures/particles_base_diffuse.dds</texture> </base_material> while your filter was set to OBJECT_MESH_DYNAMIC. So, your code after the modification may look like this: int AppWorldLogic::init() { // Write here code to be called on world initialization: initialize resources for your world scene during the world start. pod = ObjectDynamic::create(); pod->setName("POINTS"); pod->setMaterial("particles", "*"); pod->setSurfaceProperty("surface_base", "*"); pod->setSurfaceMode(ObjectDynamic::MODE_POINTS, 0); //pod->setMaterialNodeType(Node::OBJECT_MESH_DYNAMIC); pod->setMaterialNodeType(Node::OBJECT_DYNAMIC); pod->setInstancing(0); ObjectDynamic::Attribute *attrib = new ObjectDynamic::Attribute; const ObjectDynamic::Attribute attributes2[] = { { 0, ObjectDynamic::TYPE_FLOAT, 3 } ,{ 12, ObjectDynamic::TYPE_FLOAT, 2 } }; pod->setVertexFormat(attributes2, 2); pod->addPoints(65536); for (int i = 0; i < pod->getNumIndices(); i++) { vec3 vertex = vec3(Game::get()->getRandomFloat(-128.0f, 128.0f), Game::get()->getRandomFloat(-128.0f, 128.0f), Game::get()->getRandomFloat(2.0f, 64.0f)); pod->addVertexFloat(0, vertex, 3); vec2 xy = vec2(Game::get()->getRandomFloat(0.2f, 0.8f), Game::get()->getRandomFloat(0.0f, 3.1415)); pod->setVertexFloat(1, vec4(xy, 0, 0), 2); } BoundBox bb = BoundBox(vec3(-128, -128, 2), vec3(128, 128, 64)); pod->setBoundBox(bb); return 1; } And don't forget to clear your pod pointer in the shutdown(), as not doing so causes a crash: int AppWorldLogic::shutdown() { // Write here code to be called on world shutdown: delete resources that were created during world script execution to avoid memory leaks. pod.clear(); return 1; } This should solve your issue, and you'll be able to see your points rendered. Thank you! Link to comment
d83v83_ Posted January 22, 2019 Author Share Posted January 22, 2019 Sorry, I didn't recognize the difference between your post and my. After deleting the line "pod->setMaterialNodeType(Node::OBJECT_MESH_DYNAMIC);", it works! Wonderful! Link to comment
