landscape output
What are the contents of the Output folder created after the terrain was created with the lanscape tool?
 In OutputFolder, Folders named height, image, and normal are created, and there looks like data about lod.
I want to move only the node reference of the terrain node to another project because the folder is too large.
But,
If folder is missing, arise  problem about terrain node that already created in the world?
Hi @dongju.jeong,
This folder contains required terrain data, it's better not to touch these files.
If I understood everything correctly you want to re-use terrain data in multiple projects. It is possible if you transfer all terrain node data  via node reference and after that change paths to LOD data in Editor. You can do it manually in .node file as well. Don't forget to create or copy terrain global material.
