trey.coursey Posted July 30, 2018 Share Posted July 30, 2018 So I have begun to get familiar with the tracker tool. A bit different from what I'm used to, but powerful none the less in how it works. I can appreciate that as I get more familiar I think. Attached is a video of me setting up a very simple camera move. The interpolation of the keyframes is not suitable at all. I've fiddle with the curves but am not getting anything like I'd want (not shown in this video). What am I missing on this? In many other content creation tools, this camera would not dip down in the middle, why is it here in Unigine? 2018-07-30 08-56-13.mp4 Link to comment
silent Posted July 31, 2018 Share Posted July 31, 2018 Hi Trey, And what is the expected results? Maybe adding more keyframes or changing interpolation method will work? It's hard to suggest anything without knowing of which result is fit your needs. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
Greg.Mildenhall Posted July 31, 2018 Share Posted July 31, 2018 (edited) This interpolation method looks suspiciously like a slerp (spherical lerp): it turns out the shortest path between two points on the sphere of possible directions is usually not horizontal even if the two endpoints have the same height (pitch, in direction terms). To move between camera orientations, you almost always want to lerp on heading alone while keeping pitch constant. But I haven't used the tool so have no advice on how to achieve that, sorry. Edited July 31, 2018 by Greg.Mildenhall Link to comment
trey.coursey Posted July 31, 2018 Author Share Posted July 31, 2018 15 hours ago, silent said: Hi Trey, And what is the expected results? Maybe adding more keyframes or changing interpolation method will work? It's hard to suggest anything without knowing of which result is fit your needs. Thanks! as mentioned below, it's a possible interpolation mode. I've pressed the different interpolation modes with no change. Maybe some direction on how to properly use those? I'll record another video in just about any other content creation tool that will show you a typical "Default" interpolation that would keep the camera facing the target. As you can see in the video, the only thing that changed is the position and angle on the ends. In the middle the camera drops down to something that was never looked at or targeted even the slightest. So why would that be? Normally I would see just a gentle slide of the values from one to the next, giving the camera a gentle rotation, basically looking at the target area....never dipping down to who knows what or why.. :) Link to comment
silent Posted August 1, 2018 Share Posted August 1, 2018 Hi Trey, If you want camera to look at specific point while movement you will have to use special node - Player Persecutor and animate it. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
trey.coursey Posted August 1, 2018 Author Share Posted August 1, 2018 10 hours ago, silent said: Hi Trey, If you want camera to look at specific point while movement you will have to use special node - Player Persecutor and animate it. Thanks! Gotcha, and I may need that later... For now I found that the default (at least on my system) of TYPE in the tracker was set to "Inconst velocity, order XYZ" and it needed to be Inconst velocity, order ZYX. This gave me the result I was looking for and would typically find in any other content creation system I've used in the past. One more thing checked off of my list! Thanks for the help to both of you. Link to comment
