[SOLVED] Geodetic pivot is missing
The geodetic pivot is not created if the landscape is created as Flat, even though it's set up as a georeferenced terrain (2.7.1)
I must tick "Curved" for it to be generated.
Hello Stephane,
it is intended behaviour. Georeferenced means that you can use geotiff and other raster files with geodata. If you need a flat terrain with geodetic you can add this object manually: https://developer.unigine.com/en/docs/2.7.1/objects/geodetics/geodeticpivot/
  • silent changed the title to [SOLVED] Geodetic pivot is missing
