fmaslofski Posted June 16, 2018 Share Posted June 16, 2018 Would it be posible to import a non geo referenced image to replace/use the same positioning as an existing geo referenced one? Link to comment
morbid Posted June 18, 2018 Share Posted June 18, 2018 Hello, you can achieve this in two different ways: just add a required image as tileset and put it in the same coordinates as your georeferenced source manually add geodata to your raster file in 3rd-party software (QGis, GlobalMapper) The first approach will work, but it won't give you 100% match for geo/no-geo data (geodata is processed separately). The second one is more time consuming, but you can get the correct positioning of your custom source. More on tileset mode in Landscape Tool could be found here: https://developer.unigine.com/en/docs/2.7.1/editor2/landscape_tool/create_tileset Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
