de-Roo.Lukas Posted February 18, 2018 Share Posted February 18, 2018 Hi, I am a beginner in programming. May I ask what is the advantage of using uniginescript compared to C++? Link to comment
silent Posted February 19, 2018 Share Posted February 19, 2018 Hi Lukas, The main advantage that I can tell for now is that you don't need to recompile code manually to be able to run it (just do the world_reload) and all the changes will be applied. There is also a couple of tricks available: Normally for the large-scale projects it's better to use C++ API with IDE for the easy debugging. Script can be used for the really fast prototyping or for writing small parts of code that are not available in C++ (like callbacks for Tracker, for example). Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
