gary Posted December 1, 2017 Share Posted December 1, 2017 Hi, I can't figure how to import nodes from 2.5 to 2.6.0.1? The old node window's gone and the only import option i can see is for assets. Also, I'm using max 2018 and can't get the old .path to work when importing paths. G Link to comment
morbid Posted December 4, 2017 Share Posted December 4, 2017 Hi, thank you for feedback! In 2.6.0.1 you can just drag'n'drop .node file into asset browser. But usually that's not a solution. When you're creating a node in 2.6 you can place it as content\layer\noderef via context menu in Asset Browser. Can you please specify what exactly you're trying to do with 2.5 nodes? Please, be aware that you may need to migrate 2.5 project to 2.6. A manual available here. We know about .path issues and working towards solution. If you need a workaround, may I ask you for 3ds max file that you're using for path creation? How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
