cizi.kim Posted August 27, 2010 Share Posted August 27, 2010 Hi, I'm going to make a Tool to have unigine dll. It's based on the D3D9AppMFC sample. when I tried test the tool, It has often happening that is losing the UI layer - a font console screen and all kinds of UI object - in less than around 10 min. I think that it seems to be lost only UI layer. because other layers were not losing. Have you ever seen this happening? Please tell me the way to solve this problem. thank you. Link to comment
rohit.gonsalves_ Posted August 30, 2010 Share Posted August 30, 2010 Hi, I'm going to make a Tool to have unigine dll. It's based on the D3D9AppMFC sample. when I tried test the tool, It has often happening that is losing the UI layer - a font console screen and all kinds of UI object - in less than around 10 min. I think that it seems to be lost only UI layer. because other layers were not losing. Have you ever seen this happening? Please tell me the way to solve this problem. thank you. Can yoy put two screen-shots? With UI Layer and Without UI layer when UI layer lost.... Link to comment
pit Posted August 30, 2010 Share Posted August 30, 2010 Hi, Yes we saw this bug many times. We use unigine_x86.dll with some our extensions (they do not concern with graphics or ui). The bug appears both in fullscreen and window modes. But in our case application usually works properly around 10-40 minutes. Also world script and physics have stopped when this bug happens. We can only rotate camera with mouse not move it in straight line with keyboard. When editor is loaded all it's windows still there except main panel. Link to comment
Guest extaliones Posted August 31, 2010 Share Posted August 31, 2010 Hello, We will try to reproduce this bug. If you have the test scene you can upload. Link to comment
alex.dovgodko Posted September 6, 2010 Share Posted September 6, 2010 Hello, We will try to reproduce this bug. If you have the test scene you can upload. This bug seems to be unrelated to scene as we saw it in most scenes we work on (even in engine demos) many times. It happened several times even before a world is loaded (with UI window only). Also it effects not only UI layer but animation and particles as well (at least in our game). However there are systems in our office which never(!) reproduced this bug. It seems like AMD CPU systems are immune to this trouble and its root is hidden in the main board chipset or CPU. Link to comment
pit Posted September 6, 2010 Share Posted September 6, 2010 This bug seems to be unrelated to scene as we saw it in most scenes we work on (even in engine demos) many times. It happened several times even before a world is loaded (with UI window only). Also it effects not only UI layer but animation and particles as well (at least in our game). However there are systems in our office which never(!) reproduced this bug. It seems like AMD CPU systems are immune to this trouble and its root is hidden in the main board chipset or CPU. Yes, we often saw the bug on Intel CPU (Core 2 Duo and Core I5) and NEVER on AMD CPU. Link to comment
cizi.kim Posted September 15, 2010 Author Share Posted September 15, 2010 I put a screen-shot of the resource editor. it was lost the common ui. and, it's my system information below. - CPU : Intel Core2 Quad Q8200 - RAM : 4G ( 3G available ) - OS : Win XP SP3 32 bit - VGA : NVIDIA GeForce GTS 250 - VGA Driver : 6.14.12.5896 Link to comment
Guest extaliones Posted September 15, 2010 Share Posted September 15, 2010 Please, upload your builds, we can not reproduce the problem. Link to comment
cizi.kim Posted September 15, 2010 Author Share Posted September 15, 2010 Please, upload your builds, we can not reproduce the problem. I didn't change anything. I used the latest version and I just used the resource editor in the Unigine bin directory for blending two normal maps. Link to comment
Guest extaliones Posted September 16, 2010 Share Posted September 16, 2010 We really can not reproduce the problem. We use Windows 7 with Intel® Core2DuoCPU or Windows XP SP3 32 bit with AMD Athlon64x2Dual Core and never encountered such a problem. May be better to use 64-bit OS and 64-bit builds with Intel Core2 Quad Q8200. Link to comment
cizi.kim Posted September 16, 2010 Author Share Posted September 16, 2010 We really can not reproduce the problem. We use Windows 7 with Intel® Core2DuoCPU or Windows XP SP3 32 bit with AMD Athlon64x2Dual Core and never encountered such a problem. May be better to use 64-bit OS and 64-bit builds with Intel Core2 Quad Q8200. I think that it's not solution of this problem. because the most of the game player still use the Windows XP, 32-bit OS. Ok, I'll put another screen-shots if i see a same bug. Link to comment
binstream Posted September 16, 2010 Share Posted September 16, 2010 It seems to be a WinXP-releated bug. The problem is that we mainly use Vista/7 during Unigine development and testing. Link to comment
