Error loading gui resources at startup stored in .ung file
Hi all,
After moving to new Ungine 2.2, I've realized Ungine fails at initialization trying to load gui resources in a folder different from core (by specifying <item name="gui_path" type="string">my_app/gui/</item> in config file) if these resources are packed in a .ung file.
I've checked the .ung file by extracting the content and verifying the files are present and without any case variation in their names (they have exactly the same name as Unigine expects). In fact if the files are not archived the engine starts as expected.
We have some success in reproducing this issue.
It'll help however if you provide more detail.
Which one engine binary are you using: debug or release?
Are there any error messages in the log when engine fails? (by default engine saves log to the "bin/log.html")
This is a log fragment from the start to the world loading...
12:15:57
12:15:57 ---- Plugins ----
12:15:57
12:15:57 ---- Application ----
12:16:00 Loading "dxgi.dll"...
12:16:00 Loading "openal32.dll"...
12:16:00 Set 1600x900 windowed video mode
12:16:00 FontTTF::FontTTF(): can't open "F:/Izar/IPMS_v3/ALHD/apps/nux/unigine/data/nux-sailing/gui/font.ttf" file
12:16:00 ImageFilePNG::load(): can't open "F:/Izar/IPMS_v3/ALHD/apps/nux/unigine/data/nux-sailing/gui/gui_mouse.png" file
12:16:00 ImageFilePNG::load(): can't open "F:/Izar/IPMS_v3/ALHD/apps/nux/unigine/data/nux-sailing/gui/gui_background.png" file
12:16:00 ImageFilePNG::load(): can't open "F:/Izar/IPMS_v3/ALHD/apps/nux/unigine/data/nux-sailing/gui/gui_selection.png" file
12:16:00 ImageFilePNG::load(): can't open "F:/Izar/IPMS_v3/ALHD/apps/nux/unigine/data/nux-sailing/gui/gui_tooltip.png" file
12:16:00 ImageFilePNG::load(): can't open "F:/Izar/IPMS_v3/ALHD/apps/nux/unigine/data/nux-sailing/gui/gui_vpaned.png" file
12:16:00 ImageFilePNG::load(): can't open "F:/Izar/IPMS_v3/ALHD/apps/nux/unigine/data/nux-sailing/gui/gui_hpaned.png" file
12:16:00 ImageFilePNG::load(): can't open "F:/Izar/IPMS_v3/ALHD/apps/nux/unigine/data/nux-sailing/gui/gui_border.png" file
12:16:00 ImageFilePNG::load(): can't open "F:/Izar/IPMS_v3/ALHD/apps/nux/unigine/data/nux-sailing/gui/gui_tabbox.png" file
12:16:00 ImageFilePNG::load(): can't open "F:/Izar/IPMS_v3/ALHD/apps/nux/unigine/data/nux-sailing/gui/gui_window.png" file
12:16:00 ImageFilePNG::load(): can't open "F:/Izar/IPMS_v3/ALHD/apps/nux/unigine/data/nux-sailing/gui/gui_button.png" file
12:16:00 ImageFilePNG::load(): can't open "F:/Izar/IPMS_v3/ALHD/apps/nux/unigine/data/nux-sailing/gui/gui_checkbox.png" file
12:16:00 ImageFilePNG::load(): can't open "F:/Izar/IPMS_v3/ALHD/apps/nux/unigine/data/nux-sailing/gui/gui_combobox.png" file
12:16:00 ImageFilePNG::load(): can't open "F:/Izar/IPMS_v3/ALHD/apps/nux/unigine/data/nux-sailing/gui/gui_treebox.png" file
12:16:00 ImageFilePNG::load(): can't open "F:/Izar/IPMS_v3/ALHD/apps/nux/unigine/data/nux-sailing/gui/gui_vspacer.png" file
12:16:00 ImageFilePNG::load(): can't open "F:/Izar/IPMS_v3/ALHD/apps/nux/unigine/data/nux-sailing/gui/gui_hspacer.png" file
12:16:00 ImageFilePNG::load(): can't open "F:/Izar/IPMS_v3/ALHD/apps/nux/unigine/data/nux-sailing/gui/gui_vslider.png" file
12:16:00 ImageFilePNG::load(): can't open "F:/Izar/IPMS_v3/ALHD/apps/nux/unigine/data/nux-sailing/gui/gui_hslider.png" file
12:16:00 ImageFilePNG::load(): can't open "F:/Izar/IPMS_v3/ALHD/apps/nux/unigine/data/nux-sailing/gui/gui_vscroll.png" file
12:16:00 ImageFilePNG::load(): can't open "F:/Izar/IPMS_v3/ALHD/apps/nux/unigine/data/nux-sailing/gui/gui_hscroll.png" file
12:16:00 ImageFilePNG::load(): can't open "F:/Izar/IPMS_v3/ALHD/apps/nux/unigine/data/nux-sailing/gui/gui_spinbox.png" file
12:16:00 ImageFilePNG::load(): can't open "F:/Izar/IPMS_v3/ALHD/apps/nux/unigine/data/nux-sailing/gui/gui_editor.png" file
12:16:00 ImageFilePNG::load(): can't open "F:/Izar/IPMS_v3/ALHD/apps/nux/unigine/data/nux-sailing/gui/gui_white.png" file
12:16:00 Xml::load(): can't open "F:/Izar/IPMS_v3/ALHD/apps/nux/unigine/data/nux-sailing/gui/gui.rc" file
12:16:00 Gui::setResource(): can't open "F:/Izar/IPMS_v3/ALHD/apps/nux/unigine/data/nux-sailing/gui/gui.rc" file
12:16:00
12:16:00 ---- Engine ----
12:16:00 UNIGINE Engine
12:16:00 Version: 2.2 release-2.2-61859c1 Mar 16 2016
12:16:00 Binary: Windows 64-bit Visual C++ 1800 Release
12:16:00 Features: OpenGL OpenGL4.4 Direct3D11 OpenAL XAudio2 XPad360 Joystick Editor DoubleCoords HalfTexCoords Microprofile OpenEXR Geodetic
12:16:00 App path: F:/Izar/IPMS_v3/ALHD/apps/nux/bin/
12:16:00 Data path: F:/Izar/IPMS_v3/ALHD/apps/nux/unigine/data/
12:16:00 Save path: F:/Izar/IPMS_v3/ALHD/apps/nux/bin/
12:16:00
12:16:00 ---- System ----
12:16:00 OS: Windows 8 64-bit
12:16:00 CPU: Intel® Core i7 CPU 960 @ 3.20GHz 3238MHz MMX SSE SSE2 SSE3 SSSE3 SSE41 SSE42 HTT x4
12:16:00 GPU: NVIDIA GeForce GT 720 10.18.13.6191/NVIDIA GeForce GTX 970 10.18.13.6191 x1
12:16:00 System memory: 22526 MB
12:16:00 Video memory: 4096 MB
12:16:00 Sync threads: 3
12:16:00 Async threads: 4
12:16:00
12:16:00 ---- MathLib ----
12:16:00 Set SSE2 simd processor
12:16:00
12:16:01 ---- Sound ----
12:16:01 Renderer: OpenAL Soft
12:16:01 OpenAL vendor: OpenAL Community
12:16:01 OpenAL renderer: OpenAL Soft
12:16:01 OpenAL version: 1.1 ALSOFT 1.15.1
12:16:01 Found AL_EXT_LINEAR_DISTANCE
12:16:01 Found AL_EXT_OFFSET
12:16:01 Found ALC_EXT_EFX
12:16:01 Found EFX Filter
12:16:01 Found EFX Reverb
12:16:01 Found EAX Reverb
12:16:01 Found QUAD16 format
12:16:01 Found 51CHN16 format
12:16:01 Found 61CHN16 format
12:16:01 Found 71CHN16 format
12:16:01 Maximum sources: 256
12:16:01 Maximum effect slots: 4
12:16:01 Maximum auxiliary sends: 2
12:16:01
12:16:01 ---- Render ----
12:16:01 Renderer: NVidia 4007MB
12:16:01 Direct3D11 desc: NVIDIA GeForce GTX 970
12:16:01 Maximum texture size: 16384
12:16:01 Maximum texture units: 16
12:16:01 Maximum texture renders: 8
12:16:01
12:16:01 ---- Physics ----
12:16:01 Physics: Multi-threaded
12:16:01
12:16:01 ---- PathFind ----
12:16:01 PathFind: Multi-threaded
12:16:01
12:16:01 ImageFilePNG::load(): can't open "F:/Izar/IPMS_v3/ALHD/apps/nux/unigine/data/nux-sailing/gui/dialog_ok.png" file
12:16:01 ImageFilePNG::load(): can't open "F:/Izar/IPMS_v3/ALHD/apps/nux/unigine/data/nux-sailing/gui/dialog_cancel.png" file
12:16:01 ImageFilePNG::load(): can't open "F:/Izar/IPMS_v3/ALHD/apps/nux/unigine/data/nux-sailing/gui/dialog_close.png" file
12:16:01 Loading "core/materials/default/unigine_post.mat" 31 materials 9225 shaders 12ms
12:16:01 Loading "core/materials/default/unigine_render.mat" 48 materials 103050 shaders 6ms
12:16:01 Loading "core/materials/default/unigine_render_light.mat" 2 materials 23850 shaders 4ms
12:16:01 Loading "core/materials/default/unigine_decal.mat" 1 material 131850 shaders 6ms
12:16:01 Loading "core/materials/default/unigine_mesh.mat" 1 material -5159252 shaders 8ms
12:16:01 Loading "core/materials/default/unigine_mesh_stem.mat" 2 materials 4ms
12:16:01 Loading "core/materials/default/unigine_terrain.mat" 1 material 232200 shaders 4ms
12:16:01 Loading "core/materials/default/unigine_grass.mat" 2 materials 68850 shaders 5ms
12:16:01 Loading "core/materials/default/unigine_particles.mat" 1 material 47025 shaders 4ms
12:16:01 Loading "core/materials/default/unigine_billboards.mat" 4 materials 131625 shaders 5ms
12:16:01 Loading "core/materials/default/unigine_volume.mat" 6 materials 10350 shaders 5ms
12:16:01 Loading "core/materials/default/unigine_gui.mat" 2 materials 4725 shaders 5ms
12:16:01 Loading "core/materials/default/unigine_water.mat" 1 material 3600 shaders 5ms
12:16:01 Loading "core/materials/default/unigine_sky.mat" 1 material 4725 shaders 6ms
12:16:01 Loading "core/materials/default/unigine_sensor.mat" 8 materials 900 shaders 5ms
12:16:01 Loading "core/materials/default/unigine_water_global.mat" 21 materials 137700 shaders 11ms
12:16:01 Loading "core/properties/unigine.prop" 2 properties 4ms
12:16:01 ---- Interpreter ----
12:16:01 MicroProfile: Web server started on port 1337
12:16:01 Version: 2.80
12:16:01
12:16:01 Loading "nux-sailing/unigine.cpp" 67ms
12:16:01 Loading "core/locale/unigine.locale" dictionary 5ms
12:16:01 Unigine~# world_load nux-sailing/main
12:16:04 Loading "nux-sailing/main.cpp" 2744ms
Hello Ivan
We've found some problems in work with ung-files, but we could not reproduce your case
Сan you send us small test scene for reproduction?
  • 3 weeks later...
  • 4 weeks later...
Hi paralyzah and silent,
I'm afraid this problem isn't resolved in 2.2.1.
I will prepare a test scene as soon as I can.
Thanks for your help.
Working in a test scene I've found a behaviour that is confusing me.
  • I've created a project using browser.
  • I've modified data folder into another called unigine. So in both .bat files and in the config files set
  • -data_path "../unigine/"
  • I've created two copies of <data>/core/gui folder inside <data>/test_data_path as gui and gui2. In both folders I've changed the gui_background.png image to quickly see what gui skin is using.
  • Two .bat files to launch the application using each custom skin. And with another difference, the launch_debug_gui2.bat specifies gui parameter and launch_debug.bat using the gui path specified in config file.
  • I've created the test_data_path.ung with the content of the folder with the same name.
First test - Using test_data_path folder
  • launch_debug_gui2.bat: the application works Ok.
  • launch_debug.bat; the application works Ok.
Second test - Using test_data_path.ung
  • launch_debug.bat: looks like it uses default skin ignoring the configuration.
It's not exactly the problem described above, but it's a strange behavior and maybe it can help to find a solution.
Thanks.
test_data_path.zip
Hello Ivan
Thank you for test-scene - it very helped to understand what is the problem
Correct  me if I am wrong: you want use custom gui_path, and it is not detected correctly, if engine_config was packed in ung-archive?
Unfortunately, engine can not be initialized from cfg-files in ung - it's by design, we add remark in our documentation about it
You only have next ways: not to put cfg-file in ung-file or specify gui-path in command line as you do it in your test-scene, also you can replace default gui-folder in core.ung
  • 5 months later...
I am facing similar issue. We are currently migrating our product from Unigine 1 to Unigine 2.3.1
We are using ung files to specify external directories.
I have analysed the problem and checked the engine source code as well. Since in till Unigine 1, you can only set 1 data_path and gui_path default value is "core/gui/" BUT now in Unigine 2.3.1 we can set multiple data_paths and gui_path gets override
    // preparing gui path
    gui_path = normalize_dir_path(gui_path);
    if (!Dir::isAbsolute(gui_path))
        gui_path = data_paths[0] + gui_path;
Now I think even if I pass gui_path by config or command line, it will get override.
Please let me know if my understanding is correct. Also provide me a workaround.
Hi Priyank,
This override for gui_path is wrong.
As long as I can see all resources for GUI are loaded via engine file system and there is no need to provide an absolute path.
I've removed this two lines in the development branch:
I suggest you remove them too in your copy of SDK.
