[SOLVED] maximum namespace is 65535
hi,
I added a complicated script code to unigine editor.  At last, I got a wrong code "editor/editor.cpp:328:NameSpace::NameSpace(): maximum namespace is 65535". What's wrong with my code? And how should I do to solve it?
Thanks.
we are currently blocked by this issue. we can't write any more functions. it seems already reach the limitation.
I check when system loaded, it's already 63500 namespaces used. basically a {} is a namespace.
is there anyway to increase the limit?
thanks
hi unclebob:
  we couln't send all our code. but here is a test you could try. we basically extend the current unigine editor code with our own code so when unigine editor start it will load our ui too.
but currently it seems we run out of namespace.
simple copy this code to the editor.cpp and reload the editor will reproduce this behavior (it's about 10k lines of code and each line seems consider a namespace in unigine)
void test(){
		if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;
	if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;
	if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;
	if (1) int x=1;if (1) int x=1;	if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;
hi Bob:
    We are using the editor plugin in the beginning but later found editor plugin couldn't be cached. so we switched to integrated into editor.
is there anyway to increase the namespace or not count a "if" as a new namespace. I guess just the current unigine editor already use 50k namespaces.
    We have some code depends on unigine editor. so we can't use world script or system script.
hope you could give a hand.
thanks
even not reach the 65535 is still very risky. things like if you load a tracker file with lots of animation, the editor will fail with same error.
since unigine is heavily depends on scripting. I hope unigine could be improved to handle more codes.
I believe that every WorldExpression you have also counts towards this limit, and that if you have multiple WorldExpressions in the scene that use the same script (but are not clones of each other) they count double. We were our way towards the limit as well but in time found out and decided to put more logic in the world script itself rather then in nodes, to avoid code being duplicated. Specially if one of the nodes includes headers like unigine.h it went really fast, because these functions would be compiled numerous times. Still, right now with everything in worldscript and logic in nodes just referencing to the worldscript, we again reached about 89% of the limit...
Hi there, Cinetec!
If you have access to our source code, you can easily get rid of this limitation by removing:
11: #define NAMESPACE_MAX_ID			65535
and
113: if(interpreter->namespaces.size() == NAMESPACE_MAX_ID) Interpreter::error("NameSpace::NameSpace(): maximum namespace is %d\n",NAMESPACE_MAX_ID);
lines from /source/engine/interpreter/NameSpace.cpp file.
We'll consider to do the same and if our tests show us this won't break anything then we'll remove this limitation completely.
Hi, it seems the main problem are these defines:
#define NAMESPACE(ID,NUM)                (((NUM) << 16) | (ID))
#define NAMESPACE_ID(ID)				(((unsigned int)(ID)) & 0xffff)
#define NAMESPACE_NUM(ID)				(((unsigned int)(ID)) >> 16)
This if for example used to store function ids in the lower 16 bits of an integer. So I guess these macros have to be adjusted as well. This will limit the amount of members (functions, variables, arrays) of a namespace, but I don't think the 65536 limit will be reached here. I just hope all code uses these macros and there is no other place where the namespace is expected in the lower 16 bits.
Hi Michiel,
You're right, it's not that easy as I suggested earlier. You also can't just modify these defines, you have to change all usage code as well (replace int by long so you'll be able to store 32 bits for namespace id and 32 bits for namespace number).
Would it be possible to alter the bitmasks to give ID 20 bits and NUM 12 bits? So by changing 0xffff to 0xfffff and 16 to 20? This would reduce the number of allowed variables, functions, classes and arrays within a single namespace, but I don't think those come even close to the limit, even the Unigine editor (with a lot of global namespace functions) has 607 functions in the biggest of it's 47740 namespaces. Maybe for safety, it could be a preprocessor define that is off by default, to avoid that if someone did make his entire game using global functions it won't crash. Of course, if it can be turned into 32 bit it would be even better of course.
Hi Cinetec,
We are deeply sorry, but a quick test after increasing the NameSpace number shows us a lot of engine crashes. So, there is currently no easy method to increase NameSpace number. Please, consider to move some parts of your code to the system script.
We will experiment more with this issue and surely will let you know if we will have some positive results.
hi Bob and slient:
   We tried include our code in unigine.h and remove them from editor.cpp. But the namespace still exceeded. is the unigine.h already included in the editor.cpp namespace?
thanks
Good news, 18/14 approach seems to be working!
Here's the fix:
NameSpace.h file
#define BITS_VARIABLES 14
#define BITS_NAMESPACES 18
#define MASK_NAMESPACES ((unsigned int)(1 << BITS_NAMESPACES) - 1)
#define NAMESPACE(ID,NUM) (((NUM) << BITS_NAMESPACES) | ((ID) & MASK_NAMESPACES))
#define NAMESPACE_ID(ID) (((unsigned int)(ID)) & MASK_NAMESPACES)
#define NAMESPACE_NUM(ID) (((unsigned int)(ID)) >> BITS_NAMESPACES)
#define NAMESPACE_GET(MEMBER,ID) (namespaces[NAMESPACE_ID(ID)]->MEMBER[NAMESPACE_NUM(ID)])
#define NAMESPACE_ARRAY(ARRAY,ID) (ARRAY[NAMESPACE_ID(ID)][NAMESPACE_NUM(ID)])
NameSpace.cpp file
#define NAMESPACE_MAX_ID ((unsigned int)(1 << BITS_NAMESPACES) - 1)
#define NAMESPACE_MAX_NUM ((unsigned int)(1 << BITS_VARIABLES) - 1)
Update:
Also, you have to change inner array limits from short to int as well.
NameSpace.h file, line 224:
Vector<NameSpace*,int> childs;			// child namespaces
NameSpace.cpp file, line 137:
Vector<NameSpace*,int>::Iterator it = parent->childs.find(this);
