[SOLVED] image scale in tag text
Hi all,
my question is about how image scale should be defined in rich text tag. I've tried different versions of the same definition in my .ui file but it always fails as unknown image option.
Here is my last code.
<ui version="1.0">
  <window name="rpci_wnd" export="1" height="539">
    <hbox align="expand" background="1">
      <label align="expand" width="579">
        <text rich="1">
          <image src="gui/gui_white.png" scale=%40 color="#00ff00"/>FS4<right/>This is right aligned text</text>
      </label>
    </hbox>
  </window>
</ui>
Thanks in advance.
I'm afraid, only unscaled images can be defined at the beginning of a text line.
As a workaround you can add your image after some text and specify an image offset along the X axis by using the dx attribute:
    <text rich="1">
        FS4<image src="gui/gui_white.png" scale=%40 color="#00ff00" dx=-57/><right/>This is right aligned text</text>
</label>
We've added this issue to our internal bug tracker.
Sorry for inconvenience.
  • 3 weeks later...
