a.koryakin Posted March 12, 2015 Share Posted March 12, 2015 Hello I have *.max file which is containing cyrillic in surface name.Then i exported it in a *.mesh file.The problem is following.when i import *.mesh file into a world surface name looks like this So is there a way to use cyrillic in surface name in Unigine? Link to comment
sebastianbah Posted March 13, 2015 Share Posted March 13, 2015 Hello,What version of 3Ds Max do you use?Also your test model may help us to get to the root of the problem faster.Thanks! Link to comment
a.koryakin Posted March 13, 2015 Author Share Posted March 13, 2015 Helloi'm using Autodesk® 3ds Max® Design 2012 here is the mesh Цилиндр2.rar Link to comment
sebastianbah Posted March 13, 2015 Share Posted March 13, 2015 Hi,I'm afraid, Autodesk added unicode support only in 3Ds Max 2013, so it would be better not to use cyrillic with 3Ds Max 2012.Unigine supports cyrillic symbols, so there should be no problems if you use 2013 version or a later one. Link to comment
a.koryakin Posted March 13, 2015 Author Share Posted March 13, 2015 I've tryed export in 3Ds Max 2013 and its works. Thanx. Link to comment
