bertrand.remondin Posted January 27, 2015 Share Posted January 27, 2015 Hi all, I'm using Unigine 2.0 and I want to create a real space environment with player oriented by their position on the planet. To simulate the gravity, i apply a force to the bodyrigid each frame to the direction of the planet. This works fine. But when i use the function Body::setDirection, my force is no longer applied. Why? How can i apply a force and orient a body together? Thanks Link to comment
unclebob Posted January 27, 2015 Share Posted January 27, 2015 Hey Bertrand, Body::setDirection will reset all the velocities and forces. Actually, it's a helper method for Body::setTransform which do the dirty work. You need to use Body::setPreserveTransform (https://developer.unigine.com/en/docs/1.0/scripting/library/physics/class.body#setPreserveTransform_mat4_void) instead. All you need to do is to calculate the matrix properly and pass it to the function, probably by using lookAt or setTo functions (https://developer.unigine.com/en/docs/1.0/scripting/core/math.matrix). Link to comment
bertrand.remondin Posted January 27, 2015 Author Share Posted January 27, 2015 Thank you ! Link to comment
unclebob Posted January 27, 2015 Share Posted January 27, 2015 Hi, It'll be more productive if you give me the context of what you're trying to achieve as well as paste your code here just to see how you're setting new transformation matrix. Also, body transformation and node transformation is a little bit different things because body transformation won't apply immediately. If you want to apply it right after you changed it, please use Body::flushTransform. Link to comment
bertrand.remondin Posted January 28, 2015 Author Share Posted January 28, 2015 Actually, this is where I am: void applyOrientation(PlayerActor& player) { Body body = player.getBody(); Vec3 position = body.getPosition(); Vec3 up = -_currentGravity; mat4 transform = body.getTransform(); Vec3 direction = transform.m00m10m20; Vec3 dir = Vec3Rejection(direction, up); Vec3 viewPoint = position + dir; body.setPreserveTransform(setTo(position, viewPoint, up)); body.flushTransform(); } _currentGravity is a normalized Vec3 which represent the gravity orientation. I use it as the new up vector. Actually i have a problem with the playeractor which seems to not be affected by this body transformation. So i tried to use player.setUp(up) in this function and it works until the camera flip at each frame. I think it is because i need to set a good forward vector but i don't know how. Edit: I try to change the PlayerActor transform too at the same time: void applyOrientation(PlayerActor& player) { Vec3 newUp = -_currentGravity; Body body = player.getBody(); Vec3 bodyPos = body.getPosition(); mat4 bodyTr = body.getTransform(); Vec3 bodyDir = bodyTr.m00m10m20; Vec3 playerPos = player.getPosition(); mat4 playerTr = player.getTransform(); Vec3 playerDir = playerTr.m00m10m20; body.setPreserveTransform(getNewTransform(bodyPos, newUp, bodyDir)); body.flushTransform(); player.setTransform(getNewTransform(playerPos, newUp, playerDir)); } mat4 getNewTransform(Vec3& pos, Vec3& newUp, Vec3 oldDir) { Vec3 newDir = Vec3Rejection(oldDir, newUp); Vec3 viewPoint = pos + newDir; return (setTo(pos, viewPoint, newUp)); } but it erase the rotation of the actor to the up/down :( edit2: I tried to save the theta angle and reset it after the player.setTransform and it works. But it seems that the player.setTransform reset the velocity. Link to comment
unclebob Posted January 28, 2015 Share Posted January 28, 2015 Hey Bertrand, Am I correct that you're trying to achieve PlayerActor that will walk across planet surface? If so then all you need to do is to apply gravity force to its body and set up vector to the camera itself. Link to comment
bertrand.remondin Posted January 29, 2015 Author Share Posted January 29, 2015 So i tried to use player.setUp(up) in this function and it works until the camera flip at each frame I already tried this but it doesn't work as expected. But yes, this is what i want to do. edit: I made a short video to show you what's happening. https://www.youtube.com/watch?v=6qLTk39eZZQ&feature=youtu.be Link to comment
unclebob Posted January 29, 2015 Share Posted January 29, 2015 Bertrand, Thanks for video! I made a test sample for you with the explanation inside, please find it in the attachments. Place it somewhere in samples folder. playeractor_sphere.zip Link to comment
bertrand.remondin Posted January 30, 2015 Author Share Posted January 30, 2015 Thank you very much! i missed the setViewDirection thing. I think the explanation you gave me in the source file should be in the documentation because, usually, a "set" function don't make any computing. Link to comment
