eugene.litvinov Posted January 25, 2011 Share Posted January 25, 2011 Actually don't know, how it's doing on C-oriented languages, so I describe pattern at first. I have variable set of icons - from 0 to 8. This icons added/removed dynamically (player's inventory) and one click callback for they all. So, when I add object to inventory I do next: Gui gui = engine.getGui(); WidgetIcon icon = new WidgetIcon(gui, "source/textures/game/gui/item_" + id + ".png"); icon.setCallback(GUI_CLICKED, "Source::Inventory::eventCallbackRedirector", this, "eventItemClick"); itemListHBox.addChild(icon, GUI_ALIGN_LEFT); icons.append(icon); I add all icons to array icons. Now, when player clicks on icon I wont get pointer to this icon. In another languages I could do next: function eventItemClick(event:Event):void { for (var i:int = 0; i < icons.length; i++) if (event.target === icons[i]) { // I was found my dispatcher and can get some extra data, for example, I can define some parallel array with objects, and I can bind icon with object break; } } What analog I can apply in unigine? Thanks. Link to comment
eugene.litvinov Posted January 28, 2011 Author Share Posted January 28, 2011 It can be done, using next code: icon.setCallback(GUI_CLICKED, "Source::Inventory::eventItemClick", icons.size()); . . . void eventItemClick(int index) { log.message("eventItemClick: " + index + "\n"); } Now in callback passes index of the icon from icons array. But, it's not possible to use classes for UI in this case :) Link to comment
frustum Posted February 1, 2011 Share Posted February 1, 2011 Use callback redirectors. There are a lot of samples in the data/samples/widgets directory. Link to comment
eugene.litvinov Posted February 2, 2011 Author Share Posted February 2, 2011 Use callback redirectors. There are a lot of samples in the data/samples/widgets directory. Yes, I see callback redirectors - it's not very flexible to use classes for gui instead namespaces now. It could be convenient if callbacks described in classes will have class's namespace. For update icons indexes I use next functionality: void updateCallbacks() { for (int i = 0; i < icons.size(); i++) { icons[i].setCallback(GUI_CLICKED, "Source::Inventory::eventItemClick", i); } } That I call after add/remove icon of objects from inventory. Link to comment
