[SOLVED] Constructor Overloading
Hi, is constructor overloading possible in UnigineScript? I can create a default constructor with no arguments passed as an overload, but when I define 2 constructors (one having a Node argument; the other, string), I get the error "different argument prototype" (even though I don't use a prototype, but declaration directly).
You can overload but only with different argument counts from what I can see.
class Foo {
   Foo(string test) {
       log.message("constructor 1\n");
   Foo(string one, int test) {
       log.message("constructor 2\n");
void main() {
    Foo p = new Foo("xx");
    Foo r = new Foo("yy",1);
This is basically what I'm trying to do. I have increased the argument count and given an extra dummy int argument to the second overload. It could not recognize the token "argFileName" then. I don't get how it does not recognize the passed argument.
class Firefighter
    Node parentNode;
    Firefighter(Node argNode)
        parentNode = argNode;
    Firefighter(string argFileName)
        parentNode = getNodeByReference(argFileName);
Just select the argument type manually:
Firefighter(int arg)
    if(arg is string) {
      parentNode = getNodeByReference(arg);
    else if(arg is Node) {
      parentNode = arg;
    else {
      throw(__FUNC__ + ": unknown argument %s\n",typeinfo(arg));
UNIGINE script uses dynamic typing. Each function argument variable in fact is a container variable (think of it as a variant). All argument type indications (e.g. int/string/Node etc) are just textual HINTS, but actually not different types. Therefore your "overloaded" constructor definitions appear to the UNIGINE script compiler like redundant definitions
class Firefighter
    VARIANT parentNode;
    Firefighter(VARIANT argNode)
    Firefighter(VARIANT argFileName)
