Is it possible to call a user defined function from a material parameter expression
Hi all,
I have multiple Players rendering the scene. I need to set a value of  a post material parameter depending on the player. I tried callig a user defined function from post material parameter expression and select the correct parameter depending on the engine.game.getPlayer(). Howerver follwing error appears,
memory:1: Interpreter::parse_expression(): unknown token "setXXXParameter" in "setXXXParameter()" expression
Is it possible to call a user defined function from material parameter expression or is there another way tho achieve this.
