[SOLVED] AmbientSource not working
Hi
The sounds is not playing, why ?
What wrong with the following code?
init() {
setUpScreen();
void setUpScreen() {
 gameRunVideoBground = new WidgetSpriteVideo(gui,
        engine.getDataPath() + "videos/gamebackground/" + gamebackgroundVids[videoNumberGameBg]);
gameRunVideoBground.addLayer();
gameRunVideoBground.setOrder(1);
gui.addChild(gameRunVideoBground,GUI_ALIGN_EXPAND);
gameRunSoundBground = new AmbientSource(engine.getDataPath() + "videos/gamebackground/" +  gamebackgroundVids[videoNumberGameBg]);
gameRunVideoBground.setAmbientSource(gameRunSoundBground);
then in update
update() {
if(gameRunVideoBground != NULL && gameRunVideoBground.isPlaying() == 0 && state == 3 && state3Played == 1) {
            gameRunVideoBground.setVideoTime(0.01f);
            gameRunSoundBground.setLoop(1);
            gameRunSoundBground.play();
            gameRunVideoBground.play();
Hi Paul,
Sorry, can't reproduce. Please, check the <SDK>/data/samples/widgets/video_01 sample. Video and audio should play correctly here.
Also, in attached zip archive you can find simple test scene with playing video and audio. You will need to put the files in <SDK>/data directory and modify path to the video file inside script. I've tested it on your mov1.ogv file and it worked just fine.
audio_test.zip
