[SOLVED] SpeedTree Plugin unable to load
Hello everyone.
I obtained a SpeedTree plugin for Unigine a few days ago, however, I am having a few issues with loading it.
Unfortunately the plugin didn't come with any type of documentation explaining how to install it. It did however, contain a few files which were copied to their respective directories. After copying the files, I then used the 'Import Plugin for Collada' as guideline. Unfortunately, when I run the editor and open 'Tools' - 'Plugins' - 'Core' I get an error message stating 'SpeedTree plugin library is not loaded'
If you guys have any suggestions it would be much appreciated.
Ryan.
Just copy SpeedTree's *.dll files into <SDK>/lib directory and extract editor_speedtree.bat from attached zip file to the <SDK> directory (where browser.bat file is located). After that you can start editor with SpeedTree plugin via editor_speedtree.bat launcher.
editor_speedtree.zip
Unfortunately I have now stumbled across another error. When I try to import the .SRT model I get an error that states:
 "SpeedTreeImport::load(): can't load "Finaltest" file CParser::ParseHeader, expected header[sRT 05.2.0] but got [sRT 06.0.0]"
Do you guys have any suggestions as to what I could be doing wrong?
Many thanks
Ryan
Thanks again Silent.
I'll get in touch with SpeedTree to see if there is anything they can do for me.
Do you guys intend on adapting the plugin to make it compatible with version 6 any time in the near future?
Thanks.
  • 2 months later...
