werner.poetzelberger Posted April 18, 2013 Share Posted April 18, 2013 Hello, Having a counter, which should be reset after a>2. But the counter is counting up without reset. b.w. Link to comment
honya Posted April 18, 2013 Share Posted April 18, 2013 Hi Werner, it will not reset, because block value never send his value in your case, he must have set input for sending his value, so if you want constant value, use block Constant, set value on If block directly or use scheme that i created. Also you can output set only to one input. Here shema that do what you want I hope thats help you. Honya Link to comment
werner.poetzelberger Posted April 19, 2013 Author Share Posted April 19, 2013 Hello Honya, thank you, that helps. Right. So a value is a 'set value' which needs to be send each time (so it can be 'one time' too (via button e.g.)) and a constant is a fixed vaue providing the value all the time. Have to get into this as our previous logic patching system worked slightly different. I am having some troubles with the 'execution path' (white lines), will take some experiments. It would help a lot, if there would be more feedback in the schemer (skinner) itself, as which nodes are active through which path and which value will be sent or is blocked etc. Otherwise it is a bit a dance in the dark (at least for a beginner like me). For me as non programmer, these patching tools are very useful, so I like them, hopefully there will be more of this. Best. Werner. Link to comment
