Rob Posted January 31, 2013 Share Posted January 31, 2013 Is there a way to convert a mesh into a reference node? We have a lot of modular meshes in oru scene and it would be a lot better if these were converted to node references I already changed a few manually in the .world file by simply replacing the mesh node for a reference node while leaving the id and the transformation info intact but this involves a lot of work, is there an easier way to do this? We already thought about a python conversion script but me as an artist didnt get so far as I can only replace just 1 word instead a few different words What we need is this: <node type=”ObjectMesh” id=”1572192778” name=”CanyonModular35”> <mesh>Island/meshes/Canyon/ModularCanyonSingle.mesh</mesh> <surface name=”ModularCanyonSingle” max_visible_distance=”240” max_fade_distance=”150” material=”ModularCanyon” property=”surface_base” /> <surface name=”ModularCanyonSingleLOD2” min_visible_distance=”240” min_fade_distance=”150” material=”ModularCanyon” /> <transform>0.951883 -0.306293 0.0100831 0 0.306039 0.951787 0.021079 0 -0.0160534 -0.016979 0.999728 0 645.19 -730.67 50.0204 1</transform> </node> Converted into this: <node type="NodeReference" id="1572192778" name="ModularCanyonSingle34"> <reference>Island/nodes/Canyon/ModularCanyonSingle.node</reference> <transform>0.951883 -0.306293 0.0100831 0 0.306039 0.951787 0.021079 0 -0.0160534 -0.016979 0.999728 0 645.19 -730.67 50.0204 1</transform> </node> I found a tutorial about python and created this: fin = open("canyon.txt") fout = open("canyon2.txt", "wt") for line in fin: fout.write( line.replace('ObjectMesh', 'NodeReference') ) fin.close() fout.close() But as you can see that way I am only able to replace 1 word while I need to replace about 7 different words, and while doing this I also need to copy out the modular bits to a seperate file so it wont change any of the other models still inside the scene Anyone got an easy sollution for this? Link to comment
fonta.romain Posted January 31, 2013 Share Posted January 31, 2013 You could use this lib http://docs.python.org/2/library/xml.etree.elementtree.html It's not too hard to understand :) Link to comment
Rob Posted January 31, 2013 Author Share Posted January 31, 2013 You could use this lib http://docs.python.org/2/library/xml.etree.elementtree.html It's not too hard to understand :) Will have a look at it! Link to comment
Rob Posted January 31, 2013 Author Share Posted January 31, 2013 This topic can be closed we already have a working python script that does the replace for us Link to comment
fonta.romain Posted February 1, 2013 Share Posted February 1, 2013 Perhaps you could share it if it's allowed by your privacy rules as it can help some people here ;) Link to comment
Rob Posted February 1, 2013 Author Share Posted February 1, 2013 Perhaps you could share it if it's allowed by your privacy rules as it can help some people here ;) Will check if im allowed to share it :) Link to comment
