ivan.cuevas Posted September 13, 2012 Share Posted September 13, 2012 The new canvas_02 sample is very interesting to represent 3D elements over all other 3d elements. In this sample a modelview and projection matrix is created to rotate around a fake cube created with a set of lines. I tried to modify this sample in the following way: #include <samples/widgets/common/widgets.h> #include <core/scripts/utils.h> //extra #include <core/scripts/primitives.h> //extra /* */ Canvas canvas; /* */ class Canvas { Gui gui; // gui WidgetCanvas canvas; // canvas int lines[0]; // lines // constructor/destructor Canvas() { gui = engine.getGui(); // canvas canvas = new WidgetCanvas(gui); // vertices vec3 vertex[] = ( vec3(-1.0f,-1.0f,-1.0f), vec3( 1.0f,-1.0f,-1.0f), vec3( 1.0f, 1.0f,-1.0f), vec3(-1.0f, 1.0f,-1.0f), vec3(-1.0f,-1.0f, 1.0f), vec3( 1.0f,-1.0f, 1.0f), vec3( 1.0f, 1.0f, 1.0f), vec3(-1.0f, 1.0f, 1.0f), ); // indices int indices[] = ( 0, 1, 1, 2, 2, 3, 3, 0, 4, 5, 5, 6, 6, 7, 7, 4, 0, 4, 1, 5, 2, 6, 3, 7, ); // lines lines.clear(); forloop(int i = 0; indices.size(); 2) { int line = canvas.addLine(); canvas.addLinePoint(line,vertex[indices[i + 0]]); canvas.addLinePoint(line,vertex[indices[i + 1]]); lines.append(line); } gui.addChild(canvas,GUI_ALIGN_OVERLAP | GUI_ALIGN_BACKGROUND); } ~Canvas() { delete canvas; } // update void update() { //int width = engine.app.getWidth(); //int height = engine.app.getHeight(); //float time = engine.game.getTime(); // mat4 projection = scale(width / 2.0f,height / 2.0f,1.0f) * translate(1.0f,1.0f,0.0f) * perspective(60.0f,float(width) / height,0.1f,100.0f); // mat4 modelview = translate(0.0f,0.0f,-4.0f) * rotateX(time * 64.0f) * rotateZ(time * 32.0f); /* Modifications */ //get modelview and projection from player Player player= Unigine::getPlayer(); mat4 transform = player.getProjection() * player.getModelview(); foreach(int line; lines) { canvas.setLineTransform(line,transform); } } // save/restore state void __restore__() { __Canvas__(); } }; /* */ void update_scene() { while(1) { canvas.update(); wait; } } /* */ void create_scene() { canvas = new Canvas(); ObjectMeshDynamic box= Unigine::createBox(vec3(1.0f,1.0f,1.0f)); box.setMaterial("mesh_base","*"); add_editor(box); return "WidgetCanvas"; } The idea is to render the canvas cube over the mesh cube, but the canvas cube is not correctly rendered. I've tried different things, but I don't understand how setLineTransform() exactly works. Link to comment
manguste Posted September 28, 2012 Share Posted September 28, 2012 We've modified a sample widgets/canvas_02 to demonstrate how you can draw a wireframe of objects (a box in the example). You can check it in the attachment. The trick for setLineTransform() is that you have to translate coordinates from player's clip plane space (where the bottom left corner is (-1,-1) and top right one is (1,1)) to a widget space (where upper left corner is (0,0) and lower right one is(width,hight)). So you need to: flip Y axis translate coordinates to (0,0) for left corner and (2,2) for the right corner scale them by half I do hope now you understand the idea behind line transformation :) canvas_02.cpp Link to comment
ivan.cuevas Posted September 28, 2012 Author Share Posted September 28, 2012 Thans for the help :( Link to comment
