cor Posted September 13, 2012 Share Posted September 13, 2012 Hi, It seems that the cfg file is used and overwritten by each unigine app that you run. This is very confusing. When working on a project, we use all kind of settings special for this project. But when running some other project like a unigine demo, these settings may change. And after that the project you where working on behaves differently. This is very anoying. Can we have a .cfg file dedicated to our project? And be sure no other apps will overwrite it? Link to comment
carl.sutton Posted September 13, 2012 Share Posted September 13, 2012 Use the engine_config start up command line option. https://developer.unigine.com/en/docs/1.0/getting_started/command_line Link to comment
