[SOLVED] multiple trigger deleting
I am trying to remove multiple trigger created by following code
And I am using trigger.setEnterCallback(0) to remove the PhysicalTigger but I am facing an issue in removing them. Below mentioned is the scenario.
The trigger.setEnterCallback(0); works if I have only one trigger, but when I have more trigger it is not working.
int size = 0;
for(int x = 0; x <= size; x++)
ObjectMesh mesh = add_editor(new ObjectMesh("TestWork/assest/worlds/meshes/sphere_00.mesh"));
mesh.setWorldTransform(translate(Vec3(x, 0, 0.25f)));
For each mesh Object I place an Physical Trigger using my custom object "trigger" over it's location & set respective callback (Enter & Leave)
trigger.setEnterCallback("enter_callback", x);
Now I am set triggerEnterCallback(0, x) in enter_callback() function after all my operation are done in this function
But the trigger is till existing, how can I remove the trigger in above mentioned problem.
PhysicalTrigger is node just like any other node in the scene. Meaning you can delete as a node:
  • If you create it in script:
delete trigger;
  • If you create it in the world via the editor:
engine.editor.removeNode(trigger);
