steve3d Posted August 26, 2012 Share Posted August 26, 2012 well, I just want to create a DialogDate with Unigine::Widgets, my code is very very simple: #include <core/systems/widgets/widget_dialog.h> #include <core/systems/widgets/widget_editline.h> #include <core/systems/widgets/widget_label.h> #include <core/systems/widgets/widget_vbox.h> /* */ namespace Unigine::Widgets { /* */ class DialogDate : Dialog { WidgetEditLine date_el; // constructor DialogDate(string str = 0) : Dialog(str) { VBox hbox = new VBox(4, 4); addChild(hbox, ALIGN_EXPAND); hbox.addChild(new Label("Date:"), ALIGN_RIGHT); date_el = new WidgetEditLine(); hbox.addChild(date_el, ALIGN_EXPAND); } void setDate(string ds) { date_el.setText(ds); } string getDate() { return date_el.getText(): } }; /* */ int dialogDate(string &ds) { DialogDate dialog; // create dialog if(dialog == NULL) dialog = new DialogDate("Enter new Date"); dialog.setDate(ds); // show dialog dialog.arrange(); addChild(dialog,ALIGN_OVERLAP | ALIGN_CENTER); dialog.setPermanentFocus(); // wait dialog while(dialog.isDone() == 0) wait; // dialog result if(dialog.isOkClicked()) ds = dialog.getDate(); // hide dialog removeChild(dialog); return dialog.isOkClicked(); } } /* namespace Unigine::Widgets */ then when I try to use this, the engine keeps telling me following 11:15:46 owner = 0; 11:15:46 core/systems/widgets/widget_editline.h:35: Interpreter::parse(): unknown token "owner" then I decided to test it with a very very simple world, #include <core/systems/widgets/widget.h> #include <core/systems/widgets/widget_dialog_file.h> #include <core/systems/widgets/widget_window.h> int init() { Player player = new PlayerSpectator(); player.setDirection(vec3(0.755f,-1.0f,0.25f)); engine.game.setPlayer(player); using Unigine::Widgets; // Create Unigine::Widgets::Window Window window = new Window("Unigine::Widgets::Window"); // Add the widget to the rendered GUI addChild(window,ALIGN_OVERLAP | ALIGN_CENTER); return 1; } then here comes the following error 11:34:14 if(parent != NULL) parent.removeChild(this); 11:34:14 core/systems/widgets/widget.h:170: Interpreter::parse_expression(): unknown token "NULL" in "parent != NULL" expression What did I miss? or is there something wrong? I think this should be right, because the Tracker are written by Unigine::Widgets, it works fine, but why my codes didn't work? Link to comment
danni.coy Posted August 27, 2012 Share Posted August 27, 2012 NULL is defined in unigine.h you can either include it or you can use a line like #define NULL 0 at the head of the file. [edit] happen to be working on widgets today so the code just popped out at me - owner is defined in core/systems/widgets/widget.h [/edit] Link to comment
steve3d Posted August 27, 2012 Author Share Posted August 27, 2012 ok, got this, I still have to include both core/unigine.h and core/systems/widgets/widget.h. well, just another thought, why not just export these constant value directly from C++ Interpreter? NULL = 0, true = 1, false = 0, TRUE = 1, FALSE = 0, PI = 3.141592654f, PI2 = 6.283185308f, PI05 = 1.570796327f, SQRT2 = 1.414213562f, RAD2DEG = 57.29577951f, DEG2RAD = 0.017453293f, EPSILON = 1.0e-6f, INFINITY = 1.0e+9f, then this must be much more easier to write code that use these "constant" Link to comment
frustum Posted August 29, 2012 Share Posted August 29, 2012 In the current implementation Interpreter optimizes code better. Link to comment
steve3d Posted August 29, 2012 Author Share Posted August 29, 2012 does this "current" means next sdk version? Link to comment
ulf.schroeter Posted August 29, 2012 Share Posted August 29, 2012 don't think so. I would read it as "by including these constants via UNIGINE.h the script Compiler has more possibilities for code optimization than in case of c++ pre-definition" Link to comment
alexey.egorov Posted September 9, 2012 Share Posted September 9, 2012 yesterday i get the same compiling bug. i think widgets must include all they need headers for simpler using. Link to comment
manguste Posted September 10, 2012 Share Posted September 10, 2012 Ulf is right about the reason. At first it might be less convenient to keep in mind that you need to include a file, but in the end it's not much of a trouble. In our point of view, if efficient optimization for real-time is at stake, it's worth it. Link to comment
alexey.egorov Posted September 10, 2012 Share Posted September 10, 2012 Ulf is right about the reason. At first it might be less convenient to keep in mind that you need to include a file, but in the end it's not much of a trouble. In our point of view, if efficient optimization for real-time is at stake, it's worth it. sometimes, optimization is the second against usability. this is public interface, so such things must be done considering this. also, i think define guards in this case can done the same optimization. Link to comment
ulf.schroeter Posted September 10, 2012 Share Posted September 10, 2012 we are talking here about a single "#insert ".../unigine.h" statement.... Link to comment
