Character Script : Combiners
I am referring to scripts in the: data/scripts/character/ directory.
1) CombinerSubstitute... judging by the code, there is no weight input. Documentation includes example code with weight input. Typo?
2) For the combiners that inherit from CombinerComplex, which of the operands are the primary/secondary? So far I've been assuming operands[0] would be the primary, and operands[1] would be the secondary. Why do I need to know this? Because,... if the weight is 0.75... which of the two operands is more heavily weighted?
3) the operands is a vector. Consequently, when you remove the operands[0], the vector is rearranged such that operands[1] moves into index 0. I have opted to set operands[0] = NULL. THough, this breaks makes usage of operands.check(0) a little confusing, since it will return 1 even though the value is NULL. Just thought I'd mention this, in case you consider modifying this. Along that line of thought...
4) What are your intentions with the character script? Are there any plans to... improve it? extend it? redesign it?
Michael
We will fix documentation as soon as possible.
This operands take part in formula for blending two animation flows for example the CombinerAdd uses the following method:
void ObjectMeshSkinned::mulBuffer(int dst,int src0,int src1,float weight)
and fills the destination buffer by the following formulas (so in this case, primary/secondary terms do not apply):
dst_pos = src0_pos + src1_pos * weight;
dst_rot = slerp(src0_rot,src0_rot * src1_rot,weight);
dst_scale = slerp(src0_scale,src0_scale * src1_scale,weight);
int dst - Destination buffer.
int src0 - Source0 buffer.
int src1 - Source1 buffer.
float weight - Interpolation weight.
where the src0 is op[0], src1 is op[1]
3) the operands is a vector. Consequently, when you remove the operands[0], the vector is rearranged such that operands[1] moves into index 0. I have opted to set operands[0] = NULL. Though, this breaks makes usage of operands.check(0) a little confusing, since it will return 1 even though the value is NULL. Just thought I'd mention this, in case you consider modifying this. Along that line of thought...
To delete an element from a container (vector) you have to use remove method.
Syntax: container.remove(argument)
where argument is an integer position or a key of an element, which is to be removed.
Unfortunately, we are not going to update the character system.
I see, so, this code would suggest that when weight = 0, the output is based on src 0. When weight = 1, output is based on src1.
I guess I'm just calling that src0 primary, and src1 secondary, since src1 modifies src0 (by interpolation) by a given weight.
Anyways, thanks for the answers.
Are the improvements to generic flow graph going to completely alter the strucutre of the animation tree? Will I need to rewrite significant portions of my animation editor? :) wish I knew about this a week ago
We'll provide an upgrade script. Anyway animation system won't be changed in the next 2 months.
Okay, thank you for the information. I look forward to the update!
