binstream Posted December 29, 2011 Share Posted December 29, 2011 Render: Optimized SSDO blur filter. Improved quality of HDR and glow: now it is possible to fine-tune small, medium and large-sized halos. Light scattering falloff can be disabled for performance boost via render_use_scattering_falloff console command. Added detection of Intel GPUs. Added detection of new AMD HD7xxx GPUs. A grass diffuse texture can now have an arbitrary number of columns. Added two separate reflection colors (near and far) for water. Particle systems are animated using a 2D texture atlas (3D textures are no longer supported). Such approach prevents mipmap artifacts and is compatible with mobile platforms. Particles are rendered into the deferred and auxiliary buffers according to their alpha rather than color values. No more contour artifacts for objects when against the water with AA enabled. No more contour artifacts for objects when against the volumetric clouds in OpenGL and PlayStation 3. Fixed AA on Mac OS X. Fixed a lot of shaders for mobile platforms. On PlayStation 3 skinned meshes can be skinned purely on the GPU instead of the SPU, without back-face culling. This option allows for lower memory consumption at the expense of performance and can be enabled via ps3_render_use_mesh_raw console variable. Added white caps for water (an optional state). GUI: External multi-window GUI (load the Interface plugin to enable it). Improved WidgetCanvas: it is possible to assign a separate texture to each polygon as well as enable texture wrapping. Added new high-level widgets: Track and Line. Widgets fire LEAVE and FOCUS_OUT callbacks when they are hidden or disabled. Removed Qt wrapper support due to the extremely low 3D performance in its viewports. Multi-window mode of UnigineEditor: Physics: Added BodyRail for spline-driven railroad simulation. Added JointRail for train simulation. JointPin is renamed into JointParticles. Added several new physical samples: samples/joints/rail_00, samples/physics/train_00, samples/physics/car_03. UnigineScript: Variable scope is now saved by state saving. Removed is_extern_class_function() and get_extern_class_function() functions. Safe iteration of "foreach" and "foreachkey" cycles; a runtime error will be generated on invalid iterators. Optimized script compilation speed. Added support of Java-style anonymous class syntax: new Foo() { body }; Added trim() function for cutting out spaces (or other symbols) at the start and end of a string. C++ API: Added access to Unigine application window handle. Added string concatenation functions. Added support of network sockets. Added App::set() for setting an external handler to the application. Added access to DirectX device handlers. Added Gui object for external windows. Added functions for simulating keys and mouse buttons pressing. Added Unicode convertions functions for strings. App3DSurround, App3DVision, AppEyeFinity, AppSoft, AppStereo and AppWall became C++ plugins rather than stand-alone applications (and can now be found in source/plugins). New C++ plugins loading policy: plugin constructor is called at the very beginning of engine initialization, before App instance is created. Plugin init() is called at the same time as before. This means, it is possible to add filesystem packages or initialize external App in the plugin constructor. Tools: Multi-window mode in UnigineEditor due to the Interface plugin. Added object selection by frame in UnigineEditor (Ctrl + left mouse button). Added FileServer console tool for sharing data directories with engine instances over the network. Other changes: Added support of Linux on ARM platforms with OpenGL ES (scons cross=arm opengl=0 opengles=1). Refactored main applications for Android and iOS. Upgrade to Android NDK r7. Added world_show_transforms console command for visualization of WorldTransform. Fixed OpenAL-related crashes on Mac OS X. Mobile client application All Unigine mobile applications (both for iOS and Android) come together with a launcher that makes iterative development and testing fast and convenient. Instead of uploading resources onto mobile devices, the data which is stored on the development machine is simply shared over the network. To enable remote access, run the FileServer console tool on the machine and start the Unigine-based mobile application with default settings. Download links All files can be found in "Downloads" section of the portal: https://developer.unigine.com/fileserver/index 1 Link to comment
ken.mayfield Posted December 29, 2011 Share Posted December 29, 2011 Mouth is watering over multiple windows! Can't wait. Link to comment
steve3d Posted December 30, 2011 Share Posted December 30, 2011 multi-window mode is so cool!!! just tried a few minutes, if all these windows are rendered by qt, the I think it will have better performance than internal widget system. Link to comment
binstream Posted December 30, 2011 Author Share Posted December 30, 2011 Multi-window interface is based entirely on internal GUI. Link to comment
frustum Posted December 30, 2011 Share Posted December 30, 2011 Almost all high-level systems such as Schemer, Skinner and Tracker require fast 2D rendering. Qt render can't maintain performance of this systems. Native rendering works much faster.Qt plugin was removed because of that. Link to comment
cor Posted December 31, 2011 Share Posted December 31, 2011 I just downloaded the new release. Where is the 3dsurround_x86.exe? There is also no App3dSurround or AppStereo etc. Link to comment
steve3d Posted December 31, 2011 Share Posted December 31, 2011 These are plugins now, check lib folder Link to comment
steve.brodie Posted January 2, 2012 Share Posted January 2, 2012 Using the windows installer now. It says that i require windows SDK 7.1 Will this be required for any computer I want to run Unigine Editor on, or in game mode? Link to comment
steve3d Posted January 2, 2012 Share Posted January 2, 2012 No, you need this for compile source Link to comment
cor Posted January 3, 2012 Share Posted January 3, 2012 These are plugins now, check lib folder I see some .lib files and .dll files there. No executables. According the documentation I need to run the 3dsurround_x86 application. How do I use these plugins? Link to comment
frustum Posted January 3, 2012 Share Posted January 3, 2012 Just run the main.exe with the additional command line arguments: "-extern_plugin App3DSurround" main.exe -video_app direct3d11 -sound_app openal \ -data_path ../../../ -system_script sanctuary/unigine.cpp -engine_config ../../../data/demos/sanctuary/unigine.cfg \ -extern_plugin App3DSurround -extern_define RELEASE,STEREO_3D_SURROUND Link to comment
steve3d Posted January 4, 2012 Share Posted January 4, 2012 found a problem, all those cache files are created within the bin folder, no longer created in data folder, is this designed to be this way? Link to comment
steve3d Posted January 4, 2012 Share Posted January 4, 2012 got it, the cache files are now stored in project_path, but how can I set project path? seems the only way to set project path is Engine::init function. Link to comment
frustum Posted January 4, 2012 Share Posted January 4, 2012 The cache path is broken. It will be fixed in the upcoming update. You can patch the Engine.cpp file at Engine::init() function: // parse command line parse_args(argc,argv); // data directory data_path = String::pathname(app_path + ::data_path + ENGINE_DATA); // cache directory cache_path = (project_name.size()) ? save_path : data_path; Link to comment
steve3d Posted January 4, 2012 Share Posted January 4, 2012 thanks for that, the fix working. another bug, interface plugin don't process ime input, no WM_IME_COMPOSITION, so I copied the source code for processing WM_IME_COMPOSITION from appwindow.cpp, it works now. Link to comment
david.broto Posted January 4, 2012 Share Posted January 4, 2012 Thanks for the patch! When is the documentation gonna be updated? Any date? Link to comment
cor Posted January 4, 2012 Share Posted January 4, 2012 I get an error running some of the demos. For instance: When running "samples_materials_d3d9.bat" it works ok. When running "samples_materials_d3d10.bat" I get error message: --------------------------- Can't set video mode --------------------------- Direct3D10 error: 0x8007007E D3D10AppWindow::create_context(): D3D10CreateDevice1(): failed Engine::video_restart(): can't set 1024x768 windowed video mode When clicking OK, I get: --------------------------- Unigine fatal error --------------------------- Direct3D10 error: 0x8007007E D3D10AppWindow::create_context(): D3D10CreateDevice1(): failed Engine::video_restart(): can't set 1280x720 windowed video mode When running "samples_materials_d3d11.bat" I get error message: --------------------------- Unigine fatal error --------------------------- D3D11Render::D3D11Render(): 10.0 feature level is not supported Link to comment
cor Posted January 4, 2012 Share Posted January 4, 2012 I get an error running some of the demos Extra info: I have a 3 screen surround setup (3 times 1920x1080), using a GTX590 card. I had to install the latest nVidia driver (290.53) to get surround working correctly. Link to comment
frustum Posted January 4, 2012 Share Posted January 4, 2012 another bug, interface plugin don't process ime input, no WM_IME_COMPOSITION, so I copied the source code for processing WM_IME_COMPOSITION from appwindow.cpp, it works now. IME composition will be available in the next SDK. Link to comment
frustum Posted January 4, 2012 Share Posted January 4, 2012 I have a 3 screen surround setup (3 times 1920x1080), using a GTX590 card. I had to install the latest nVidia driver (290.53) to get surround working correctly. Try to use Direct3D11 render. Link to comment
cor Posted January 4, 2012 Share Posted January 4, 2012 Try to use Direct3D11 render. When running "samples_materials_d3d11.bat" I get error message: --------------------------- Unigine fatal error --------------------------- D3D11Render::D3D11Render(): 10.0 feature level is not supported Link to comment
ulf.schroeter Posted January 4, 2012 Share Posted January 4, 2012 What kind of GPU do you use ? Link to comment
cor Posted January 4, 2012 Share Posted January 4, 2012 GTX590 with 3 connected displays (surround setup) Link to comment
cor Posted January 6, 2012 Share Posted January 6, 2012 When running "samples_materials_d3d11.bat" I get error message: --------------------------- Unigine fatal error --------------------------- D3D11Render::D3D11Render(): 10.0 feature level is not supported Can anybody advise me what to do? I'm stuck with this. Some demos of the latest release do not work with my setup. They should, don't they? What does the error message mean? What does it mean when "10.0 feature level is not supported" ? Link to comment
steve3d Posted January 6, 2012 Share Posted January 6, 2012 It should work, try to use only one monitor. Link to comment
