Microprofile
UNIGINE has support for Microprofile, an advanced external embeddable CPU/GPU profiler with support for per-frame inspection.
Microprofile Tool
The profiler features the following:
  • Profiling operations performed by the engine on CPU and GPU.
  • Profiling the engine threads.
  • Profiling up to 1000 frames.
  • The performance data output to a local web server.
Running Microprofile#
The Microprofile tool is available only for the Development builds of UNIGINE Engine: it won't be compiled for the Debug and Release ones. You can use the microprofile_info console command to check if the Microprofile is compiled.
The performance data obtained by the Microprofile can be output to a local web server.
The Microprofile shows valid information only after the first 1000 frames are rendered (e.g. at the framerate of 60 FPS, such "warmup" time comprises about 16 seconds).
Enabling and Disabling Microprofile#
Microprofile is performance-consuming, that's why we recommend you to enable it only when you work with it and keep disabled otherwise.
One way to disable Microprofile is to untick the corresponding option before running UnigineEditor or the application:
Disabling Microprofile via SDK Browser
Another way is to use the microprofile_enabled console command.
If you change the Microprofile status via the console, this setting is saved in the <Project_Name>/data/configs/default.user file. The state set in the user configuration file will override the state defined via SDK Browser.
Visualization Using Built-In Server#
To visualize the performance data using the local web server, perform the following:
  1. In the console, set the the number of frames to be profiled via the microprofile_webserver_frames console command. You can skip this step: by default, 200 frames will be profiled.
  2. On the Menu Bar of UnigineEditor, choose Tools -> Microprofile.
The performance data will be displayed in your Web browser.
  • You can display only a part of the profiled frames: in the Web browser address bar, add /<number_of_frames> to the current URL.
  • Don't forget to refresh (F5) the page in the Web browser while the profiling data is collected as it is not performed automatically.
For example, if you specify localhost:1337/100, only the first 100 frames will be displayed.
All available console commands can be found in the Performance Profiling section of the article on Console.
Performance Data#
The Microprofile visualizes the detailed per frame performance data on the operations performed by the engine on CPU and GPU and on the engine threads. In the Microprofile main menu, you can change the visualization mode: click Mode and choose the required one. By default, the Detailed mode is set.
Profiling Groups Displayed in Detailed Mode
In the Detailed mode, each operation (function) and thread is displayed as a separate colored region. The regions are hierarchical: the function called by the other function is displayed under the last one. The size of the region is determined by the time the corresponding operation takes.
In the picture below, the Engine::do_render() function calls the RenderRenderer::renderWorld() functions and so on:
To view the data on a certain operation or a thread, point to the corresponding region. To zoom in/out the displayed regions, scroll the mouse wheel.
CPU Data#
In the Main group of the performance data, the call stack of the operations (e.g., update, rendering, etc.) performed by the engine on CPU is displayed.
Performance Data on World Update Function
GPU Data#
In the GPU group of the performance data, the call stack of the operations performed by the engine on GPU is displayed. In addition to the main performance data, for each function (e.g. environment rendering, post materials rendering and so on), the number of DIP calls and rendered triangles is shown. Also there can be the number of surfaces, lights, shadows rendered by this function, the number of materials and shaders used; the information on the node or material for which the function is called (identifier, name, etc.).
Performance Data on Deferred Lighting Rendering
When the region that corresponds to the certain function is pointed, the Microprofile displays when this function is called on CPU and how much time is spent on its performing.
OpenGL or DirectX commands can be combined into GPU Debug groups that are created automatically when defining a profiling scope. All graphic resources loaded from external files, such as textures, shaders, static or skinned meshes, as well as the Engine's internal resources, have their own debug names to simplify identification. This information can be useful when using Graphics API debuggers, such as NVIDIA Nsight or RenderDoc.
Example of debug data viewed in RenderDoc
Engine Threads Data#
The performance data on the engine threads is visualized in the CPUThread, SoundThread, AsyncQueueThread, WorldSpawnMeshClutterThread, WorldSpawnGrassThread groups.
Performance Data on Physics Thread
Using Microprofile For Application Logic#
You can use the Microprofile to inspect performance of your application logic.
  1. Open the source code of your application.
  2. Include the UnigineProfiler.h file to get access to methods of the Profiler class.
    AppWorldLogic.h
    #include <UnigineProfiler.h>
  3. Find a function or a scope in the code you want to inspect.
  4. In the beginning of the function (or the scope), call Profiler::begin(). Specify a name for the capture to be displayed in the Microprofile.
    You can specify the __FUNCTION__ macro to automatically use the class and the function name as the capture.
  5. In the end of the function (scope), call Profiler::end().
    AppWorldLogic.cpp
    int AppWorldLogic::update()
    	// start profiling
    	Profiler::begin("AppWorldLogic::update");
    	float time = Game::getTime();
    	float angle_0 = time * 1.0f;
    	float angle_1 = time * 1.5f;
    	float angle_2 = time * 2.0f;
    	light_0->setWorldTransform(translate(Unigine::Math::Vec3(sinf(angle_0), cosf(angle_0), 1.0f) * 20.0f));
    	light_1->setWorldTransform(translate(Unigine::Math::Vec3(sinf(angle_1), cosf(angle_1), 1.0f) * 20.0f));
    	light_2->setWorldTransform(translate(Unigine::Math::Vec3(sinf(angle_2), cosf(angle_2), 1.0f) * 20.0f));
    	// stop profiling
    	Profiler::end();
  6. Run the project.
  7. Open the console and run the microprofile_enabled 1 command.
  8. Go to the Microprofile and find the region with the specified name.
The begin() and end() functions make the profiling scope available for both the Profiler and Microprofile.
If you want to use Microprofile only, create the counter via the beginMicro() and endMicro() functions.
beginMicro() returns an identifier that should be passed to endMicro(). Thus, several nested counters can be created.
AppWorldLogic.cpp
	// start profiling
	int id = Profiler::beginMicro("AppWorldLogic::update");
	// stop profiling
	Profiler::endMicro(id);
Creating Nested Counters for Profiling#
To create several nested counters, you should use the beginMicro() and endMicro() functions. beginMicro() returns an identifier that should be passed to endMicro(). This enables to create nested and intersecting profiler counters.
In the following example, combination of begin()/end() and beginMicro()/endMicro() is used. So, profiling of the AppWorldLogic::update() function will be available in both the Profiler and the Microprofile.
AppWorldLogic.cpp
	// start profiling
	// start profiling of the first light source (available in the Microprofile only)
	int id_0 = Profiler::beginMicro("1st Light Update");
	// stop profiling of the first light source
	Profiler::endMicro(id_0);
	// start profiling of the second light source (available in the Microprofile only)
	int id_1 = Profiler::beginMicro("2nd Light Update");
	// stop profiling of the second light source
	Profiler::endMicro(id_1);
	// stop profiling
	Profiler::end();
Use only beginMicro()/endMicro(), if you don't need the Profiler tool.
Profiling Logic Using Macros#
There are special macros to mark fragments of your code that should be inspected. They can be used instead of the beginMicro() and endMicro() functions:
  • UNIGINE_PROFILER_FUNCTION to inspect performance of the function.
    Using Macro Using Functions
    void myFunction()
    	UNIGINE_PROFILER_FUNCTION;
    	// your function code
    void myFunction()
    	int id = Profiler::beginMicro(__FUNCTION__);
  • UNIGINE_PROFILER_SCOPED to inspect only a certain part of the code.
    void myFunction()
    		UNIGINE_PROFILER_SCOPED("Scope name");
    void myFunction()
    		int id = Profiler::beginMicro("Scope name");
Video Tutorial: Performance Inspection with Microprofile#
Last update: 2023-10-05
