Sector
A sector is a cuboid shaped object that culls all objects outside its volume. Sectors usage is very convenient for designing of indoor spaces. Sectors are connected by portals.
By default, shadows from the culled objects remain visible. To disable shadows rendering, go to Windows -> Settings -> Occlusion Culling and enable Shadows Culling or run the console command render_occluders_shadows 1.
Creating a Sector#
To create a world sector via UnigineEditor:
  1. On the Menu bar, choose Create -> Optimization -> Sector
    Sector Creation
  2. Place the node in the scene.
Editing a Sector#
In the Node tab of the Parameters window, you can adjust the following parameters of the world sector:
Node tab of the World Sector node
Bounding Box Parameters
Edit Size Toggles the editing mode for the world sector node on and off. When enabled, the bounding box sides that can be resized are highlighted with the colored rectangles. To change the size of a side, drag the corresponding rectangle.
Size The size of the sector's bounding box along the X, Y, and Z axes, in units.
Last update: 2019-02-14
