Controlling the Game Process
Implementing the GameController component that manages switching between the game states depending on the occurrence of certain events: all enemies are killed, player gets killed or time runs out.
The game should have different states depending on the occurrence of certain events. For example, you can add tracking the list of enemies, and if the list is empty the player has won. The game will end in defeat if the player is killed.
To switch between Gameplay and Win/Lose states, we have the GameController component.
Create the GameController component and copy the following code into it:
GameController.h
#pragma once
#include <UnigineGame.h>
// game states
enum GameState
Gameplay,
Win,
Lose,
class GameController :
public Unigine::ComponentBase
COMPONENT_DEFINE(GameController, Unigine::ComponentBase);
// current state of the game process
GameState state;
// camera for the game final (Player only)
PROP_PARAM(Node, EndCamera, nullptr);
COMPONENT_INIT(init);
COMPONENT_UPDATE(update);
// indicator of displaying the end-game screen
bool end_screen = false;
// world main loop overrides
void init();
void update();
GameController.cpp
#include "GameController.h"
#include "HUD.h"
#include "EnemyLogic.h"
REGISTER_COMPONENT(GameController);
void GameController::init()
// check whether the end-game camera is assigned and whether it is a Player
if(EndCamera && !EndCamera->isPlayer())
Log::error("GameController error: %s is not a Player-node, it cannnot be used as an EndCamera.\n", EndCamera->getName());
EndCamera = nullptr;
// set the initial state of the game
state = GameState::Gameplay;
void GameController::update()
// if the game is over
if (state != GameState::Gameplay)
if (!end_screen && EndCamera)
// switch to the camera for the game final
Game::setPlayer(checked_ptr_cast<Player>(EndCamera.get()));
// show the message about the game end in HUD
ComponentSystem::get()->getComponentInWorld<HUD>()->displayStateMessage(state);
end_screen = true;
else
// if there are no more enemies left, go to the state 'Win'
if (!ComponentSystem::get()->getComponentInWorld<EnemyLogic>() || !ComponentSystem::get()->getComponentInWorld<EnemyLogic>()->isEnabled())
state = GameState::Win;
So let's add the displayStateMessage() method to the HUD component to display the game result:
HUD.cpp
// to display the final result message
void HUD::displayStateMessage(GameState state)
// add WidgetLabel to display the final result message, set font size and color
WidgetLabelPtr end_message = WidgetLabel::create(screenGui, (state == GameState::Win) ? "You won!" : "You lost!");
end_message->setFontSize(100);
end_message->setFontColor(vec4_red);
screenGui->addChild(end_message, Gui::ALIGN_CENTER | Gui::ALIGN_OVERLAP);
// bind the widget lifetime to the world
end_message->setLifetime(Widget::LIFETIME_WORLD);
// finalize the process
ComponentSystem::get()->getComponentInWorld<GameController>()->setEnabled(false);
Next, modify code in the EnemyLogic and PlayerLogic components to use the logic of GameController:
EnemyLogic.h
#pragma once
#include "Health.h"
${#HL}$
#include "GameController.h" ${HL#}$
#include "EnemyFireController.h"
class EnemyLogic :
COMPONENT_DEFINE(EnemyLogic, Unigine::ComponentBase);
// declare the enemy states
enum EnemyLogicState
Idle,
Chase,
Attack,
PROP_PARAM(Node, player, nullptr);
PROP_PARAM(Node, intersectionSocket, nullptr);
PROP_PARAM(Mask, playerIntersectionMask, ~0);
PROP_PARAM(File, hitPrefab, "");
PROP_PARAM(Float, reachRadius, 0.5);
PROP_PARAM(Float, attackInnerRadius, 5.0f);
PROP_PARAM(Float, attackOuterRadius, 7.0f);
PROP_PARAM(Float, speed, 1.0f);
PROP_PARAM(Float, rotationStiffness, 8);
PROP_PARAM(Float, routeRecalculationInterval, 3.0f);
PROP_PARAM(Int, damage, 1);
PROP_PARAM(Mask, intersectionMask, ~0);
protected:
void init();
void update();
bool isTargetVisible();
void updateRoute();
void updateTargetState();
void updateOrientation();
void processIdleState();
void processChaseState();
void processAttackState();
// initializing the enemy state
EnemyLogicState currentState = EnemyLogicState::Idle;
bool targetIsVisible;
Unigine::Math::Vec3 lastSeenPosition;
Unigine::Math::vec3 lastSeenDirection;
float lastSeenDistanceSqr;
Unigine::BodyRigidPtr bodyRigid = nullptr;
Unigine::WorldIntersectionPtr hitInfo = Unigine::WorldIntersection::create();
Unigine::Vector<Unigine::NodePtr> hitExcludes;
EnemyFireController *fireController = nullptr;
Health *health = nullptr;
${#HL}$
GameController *gameController = nullptr; ${HL#}$
// creating a queue for route points
Unigine::Vector<Unigine::Math::Vec3> calculatedRoute;
Unigine::PathRoutePtr route = Unigine::PathRoute::create();
bool shouldUpdateRoute = true;
float lastCalculationTime = 0.0f;
EnemyLogic.cpp
REGISTER_COMPONENT(EnemyLogic);
bool EnemyLogic::isTargetVisible()
Vec3 direction = (player->getWorldPosition() - intersectionSocket->getWorldPosition());
Vec3 p0 = intersectionSocket->getWorldPosition();
Vec3 p1 = p0 + direction;
Unigine::ObjectPtr hitObject = World::getIntersection(p0, p1, playerIntersectionMask.get(), hitExcludes, hitInfo);
if (!hitObject)
return false;
return player->getID() == hitObject->getID();
void EnemyLogic::updateRoute()
if (Game::getTime() - lastCalculationTime < routeRecalculationInterval)
return;
if (shouldUpdateRoute)
// calculate the route to the player
route->create2D(node->getWorldPosition(), lastSeenPosition, 1);
shouldUpdateRoute = false;
// if route calculation is over
if (route->isReady())
// check if the target point was reached
if (route->isReached())
// clear the queue of path points
calculatedRoute.clear();
// add all root points to the queue
for (int i = 1; i < route->getNumPoints(); ++i)
calculatedRoute.append(route->getPoint(i));
lastCalculationTime = Game::getTime();
else
// recalculate the route if the target point wasn't reached
void EnemyLogic::updateTargetState()
// refresh the current visibility state
targetIsVisible = isTargetVisible();
// if the player is visible, remember his latest registered position
if (targetIsVisible)
lastSeenPosition = player->getWorldPosition();
lastSeenDirection = (vec3)(lastSeenPosition - node->getWorldPosition());
lastSeenDistanceSqr = lastSeenDirection.length2();
lastSeenDirection.normalize();
void EnemyLogic::updateOrientation()
direction.z = 0.0f;
quat targetRotation = quat(Math::setTo(vec3_zero, direction.normalize(), vec3_up, Math::AXIS_Y));
quat currentRotation = node->getWorldRotation();
currentRotation = Math::slerp(currentRotation, targetRotation, Game::getIFps() * rotationStiffness);
node->setWorldRotation(currentRotation);
void EnemyLogic::processIdleState()
// if the target is visible (player) - shift Idle -> Chase
currentState = EnemyLogicState::Chase;
void EnemyLogic::processChaseState()
vec3 currentVelocity = bodyRigid->getLinearVelocity();
currentVelocity.x = 0.0f;
currentVelocity.y = 0.0f;
if (calculatedRoute.size() > 0)
float distanceToTargetSqr = (calculatedRoute.first() - node->getWorldPosition()).length2();
bool targetReached = (distanceToTargetSqr < reachRadius* reachRadius);
if (targetReached)
calculatedRoute.removeFirst();
vec3 direction = calculatedRoute.first() - node->getWorldPosition();
direction.z = 0.0f;
direction.normalize();
// check distance and shift Chase -> Attack
if (!targetIsVisible)
currentState = EnemyLogicState::Attack;
// start shooting
if (fireController)
fireController->startFiring();
bodyRigid->setLinearVelocity(currentVelocity);
void EnemyLogic::processAttackState()
// check distance and shift Attack -> Chase
if (!targetIsVisible || lastSeenDistanceSqr > attackOuterRadius * attackOuterRadius)
// stop shooting
if (fireController)
fireController->stopFiring();
void EnemyLogic::init()
// initialize the parameters of the point moving along the path within navigational mesh
route->setRadius(0.0f);
route->setHeight(1.0f);
route->setMaxAngle(0.5f);
bodyRigid = node->getObjectBodyRigid();
hitExcludes.append(node);
hitExcludes.append(node->getChild(0));
targetIsVisible = false;
// getting the EnemyFireController component
fireController = ComponentSystem::get()->getComponent<EnemyFireController>(node);
// getting the Health component
health = ComponentSystem::get()->getComponentInChildren<Health>(node);
${#HL}$
// getting a link to the Game Manager component (GameController)
gameController = ComponentSystem::get()->getComponentInWorld<GameController>(); ${HL#}$
void EnemyLogic::update()
${#HL}$
// check the current state, if the gameplay is stopped, the enemy doesn't perform any actions
if (gameController->state != GameState::Gameplay)
return; ${HL#}$
// check the enemy's health
if (health && health->isDead())
// remove the enemy, if its health is reduced to zero
node.deleteLater();
updateRoute();
// switching between the enemy states
switch (currentState)
case EnemyLogicState::Idle: processIdleState(); break;
case EnemyLogicState::Chase: processChaseState(); break;
case EnemyLogicState::Attack: processAttackState(); break;
// changing color depending on the current state
vec4 color = vec4_black;
case EnemyLogicState::Idle: color = vec4_blue; break;
case EnemyLogicState::Chase: color = vec4(1.0f, 1.0f, 0.0f, 1.0f); break;
case EnemyLogicState::Attack: color = vec4_red; break;
// visualize the enemy states
Visualizer::renderPoint3D(node->getWorldPosition() + vec3_up * 2.0f, 0.25f, color);
Visualizer::renderPoint3D(node->getWorldPosition() + vec3_up * 3.0f, 0.25f, isTargetVisible() ? vec4_green : vec4_red);
Visualizer::renderPoint3D(lastSeenPosition, 0.1f, vec4(1.0f, 0.0f, 1.0f, 1.0f));
// visualize the attack radius
Visualizer::renderSphere(attackInnerRadius, node->getWorldTransform(), vec4_red);
Visualizer::renderSphere(attackOuterRadius, node->getWorldTransform(), vec4_red);
// visualize the route points
for(Vec3 route_point: calculatedRoute)
Visualizer::renderPoint3D(route_point + vec3_up, 0.25f, vec4_black);
PlayerLogic.h
#pragma once
#include "Health.h"
${#HL}$
class PlayerLogic :
COMPONENT_DEFINE(PlayerLogic, Unigine::ComponentBase);
COMPONENT_INIT(init,2);
// player's health
${#HL}$
// link to the Game Manager
GameController* gameController = nullptr; ${HL#}$
void init();
void update();
PlayerLogic.cpp
#include "PlayerLogic.h"
#include "FirstPersonController.h"
#include "HUD.h"
#include "WeaponController.h"
#include "ShootInput.h"
REGISTER_COMPONENT(PlayerLogic);
void PlayerLogic::init()
// take the Health component from a node
// updating info on initial player's health
ComponentSystem::get()->getComponentInWorld<HUD>()->updateHealthInfo(health->health);
${#HL}$
void PlayerLogic::update()
${#HL}$
// check the player's health and, if he was killed, remove him and switch the game to the 'Lose' state
// remove the player
node.deleteLater();
// switch the gameplay state to Lose
gameController->state = GameState::Lose;
// check the game state, if completed, remove the player
else if (gameController->state != GameState::Gameplay)
node.deleteLater(); ${HL#}$
Save all the files that we modified and then build and run the application by hitting Ctrl + F5 to make the Component System update properties used to assign the components to nodes. Close the application after running it and switch to UnigineEditor.
Create a NodeDummy, name it gameplay_systems, and assign the GameController component to it.
- For the game ending, let's create a separate camera that will look at the scene from above. Choose Create -> Camera -> Player Dummy in the menu. Rename the camera to end_camera. Switch to this camera in the Editor and control the camera to select the desired scene view.
Drag the end_camera node to the End Camera field of the GameController component assigned to the gameplay_systems node.
Now your can add more enemies and test the game.
To generate an arbitrary number of enemies, add a few lines to the GameController component:
GameController.h
Source code (C++)#pragma once #include <UnigineComponentSystem.h> #include <UnigineGame.h> // game states enum GameState { Gameplay, Win, Lose, }; class GameController : public Unigine::ComponentBase { public: COMPONENT_DEFINE(GameController, Unigine::ComponentBase); // current state of the game process GameState state; // camera for the game final (Player only) PROP_PARAM(Node, EndCamera, nullptr); ${#HL}$ // enemy spawn point PROP_PARAM(Node, spawnPoint, nullptr); // .node asset with enemy template PROP_PARAM(File, enemyPrefab, nullptr); // number of enemies PROP_PARAM(Int, numEnemies, 1); // enemy spawn interval PROP_PARAM(Float, spawnInterval, 2.0f); int spawned_enemy_counter = 0; float currentTime = 0.0f; ${HL#}$ // declare methods to be called at the corresponding stages of the execution sequence COMPONENT_INIT(init); COMPONENT_UPDATE(update); private: // indicator of displaying the end-game screen bool end_screen = false; // world main loop overrides void init(); void update(); };
GameController.cpp
Source code (C++)#include "GameController.h" #include "HUD.h" #include "EnemyLogic.h" REGISTER_COMPONENT(GameController); using namespace Unigine; using namespace Math; void GameController::init() { // check whether the end-game camera is assigned and whether it is a Player if(EndCamera && !EndCamera->isPlayer()) { Log::error("GameController error: %s is not a Player-node, it cannnot be used as an EndCamera.\n", EndCamera->getName()); EndCamera = nullptr; } // set the initial state of the game state = GameState::Gameplay; } void GameController::update() { // if the game is over if (state != GameState::Gameplay) { if (!end_screen && EndCamera) { // switch to the camera for the game final Game::setPlayer(checked_ptr_cast<Player>(EndCamera.get())); // show the message about the game end in HUD ComponentSystem::get()->getComponentInWorld<HUD>()->displayStateMessage(state); end_screen = true; } } else { // if there are no more enemies left, go to the state 'Win' ${#HL}$ if ((!ComponentSystem::get()->getComponentInWorld<EnemyLogic>() || !ComponentSystem::get()->getComponentInWorld<EnemyLogic>()->isEnabled()) && spawned_enemy_counter == numEnemies) ${HL#}$ state = GameState::Win; ${#HL}$ // generate new enemies (enemyPrefab) at a given point (SpawnPoint) with a specified time interval spawnInterval) if (spawned_enemy_counter < numEnemies && !enemyPrefab.nullCheck()) { currentTime += Game::getIFps(); if (currentTime > spawnInterval) { currentTime -= spawnInterval; spawned_enemy_counter++; World::loadNode(Unigine::FileSystem::guidToPath(FileSystem::getGUID(enemyPrefab.getRaw())))->setTransform(spawnPoint->getWorldTransform()); } } ${HL#}$ } }
- Create the Node Dummy node and place it to the point where new enemies will appear and name it spawn_point.
Drag the spawn_point node to the Spawn Point field, and the robot_enemy.node asset – to the Enemy Prefab field, and set the number of enemies and their spawn interval in seconds.
Now, let's get down to business!
