Portal
A portal is a rectangular opening between two adjacent sectors, through which one sector can be partially seen if looking from another.
A Portal between Sectors
Creating a Portal#
To create a world portal via UnigineEditor:
  1. On the Menu bar, choose Create -> Optimization -> Portal
  2. Place the node in the scene.
Editing a Portal#
In the World Portal tab of the Parameters window you can adjust the following parameters of the portal:
World Portal tab
Edit Size Toggles the editing mode for the world portal node on and off. When enabled, the portal's rectangle sides that can be resized are highlighted with the colored rectangles. To change the size of a side, drag the corresponding rectangle.
Width The width of the portal's rectangle, in units.
Height The height of the portal's rectangle, in units.
Last update: 2018-12-27
