Node Dummy
A
dummy node is a zero-sized node that has no visual representation. It is used to organize the other nodes into a hierarchy.
Usually the dummy node serves as a parent node for a group of nodes of the same type.
The dummy node, though invisible, has the same common options as other nodes: it can be transformed (moved, rotated or scaled) and have a property assigned.
The dummy node differs from the dummy object: you cannot assign physical properties to the dummy node.
- A NodeDummy class to edit dummy nodes via UnigineScript
Creating a Dummy Node#
To add a dummy node to the scene via UnigineEditor do the following:
- Run UnigineEditor.
- On the Menu bar, click Create -> Node -> Dummy.
- Place the dummy node somewhere in the world.
The dummy node is created automatically when grouping the selected nodes.
Organizing Nodes Hierarchy#
See how to Organize Nodes via the UNIGINE Editor 2.
