Obstacle Box
An obstacle box is a cuboid-shaped obstacle that is detected and bypassed by other objects during pathfinding. The obstacle box can be added, for example:
  • For the cuboid-shaped nodes (buildings, old-fashioned cars, fences and so on) that are placed inside a navigation area and should be bypassed.
  • For the areas (rivers, swimming pools and so on) that should be bypassed.
An obstacle box and a building
  • The ObstacleBox class to manage box obstacles via API
    1. obstacle_00
    2. route_01
    3. route_02
Adding Obstacle Box#
To add an obstacle box to the scene via UnigineEditor:
  1. Run UnigineEditor.
  2. On the Menu bar, click Create -> Navigation -> Obstacle Box.
The new obstacle box will be added to UnigineEditor and you will be able to edit it via the Parameters window. See also the example on obstacle box usage.
Editing Obstacle Box#
In the Obstacle Box tab of the Parameters window, you can adjust the following parameters of the obstacle box:
Obstacle Mask Obstacle mask. The obstacle mask of the obstacle box must match the obstacle mask of the route that is calculated during pathfinding. Otherwise, the obstacle will not be taken into account during pathfinding. Also by using the obstacle mask, you can specify obstacle boxes that should be ignored during pathfinding.
Size Size of the obstacle box along the axes in units.
Last update: 2018-12-27
