Content Migration
You can upgrade content of your project to UNIGINE 2.7.3 in the automatic or manual mode.
Automatic Upgrade#
Automatic upgrade of the project's content can be performed via UNIGINE SDK Browser.
By default, the automatic mode is used to upgrade only binary executable files and content stored in the project's data folder. If you have content stored outside the data folder or in the additional data folders, you will have to upgrade it manually.
In the result, the binary executable and configuration files, meshes, terrains, worlds, nodes, splines, materials, properties, tracks, settings files will be upgraded to new formats (if any). The <unigine_project>/migration.log.html log file will be opened in the web browser. However, you can uncheck Migrate Content during automatic upgrading and perform content upgrading manually. In this case, only binary executable files will be upgraded.
The migration results depend on the version of UNIGINE SDK, from which you are going to migrate.
Manual Upgrade#
This mode should be used to upgrade content stored outside the project's data folder:
To upgrade the project's content in the manual mode, do the following:
  1. Put the binary executable <UnigineSDK>/bin/usc_x64.exe (or <UnigineSDK>/bin/usc_x86.exe) to the <UnigineSDK>/utils/upgrade folder that contains the upgrade script.
  2. In the command prompt, run the upgrade.usc with the required options:
    Shell commands
    usc_x64.exe upgrade.usc path/to/the/additional_content_1 path/to/the/additional_content_2 ...
    If you have unchecked Migrate Content during automatic upgrading, add the path to the project's data folder to the list of arguments passed to the upgrade script. For example:
    Shell commands
    usc_x64.exe upgrade.usc <unigine_project>/data path/to/the/additional_content_1 path/to/the/additional_content_2 ...
    Here:
    • path/to/the/additional_content_* - paths to folders with content stored outside the data folder.
As a result, you will get your meshes, terrains, worlds, nodes, splines, materials, properties, tracks, configuration and settings files upgraded.
ObjectTerrain To ObjectTerrainGlobal Migration#
The process of migrating your ObjectTerrain to ObjectTerrainGlobal is described in detail in this article.
The only difference is that Terrain Migration Tool for 2.7.3 creates a new <terrain_name>_terrain_migration_files folder every time you click Migrate. Each of these folders has a postfix indicating the number of the corresponding migration procedure, e.g.:
  • myterrain_terrain_migration_files_1
  • myterrain_terrain_migration_files_2
  • myterrain_terrain_migration_files_14
After successful migration you should keep only one folder, generated by the corresponding migration procedure, and manually delete all other <terrain_name>_terrain_migration_files_* folders to free disk space.
Last update: 2018-12-27
