Dynamic Meshes
The article describes operations on dynamic meshes via the code by using methods of the ObjectMeshDynamic claas. This class is used to procedurally create dynamic meshes and modify them in run-time. You can also load an existing mesh as a dynamic one in order to modify it.
- An ObjectMeshDynamic class to edit dynamic meshes via UnigineScript
- A set of samples located in the data/samples/objects/ directory:
Creating a Dynamic Mesh#
- Add a new dynamic mesh via UnigineEditor.
- Create a new dynamic mesh by adding vertices.
- Create a new dynamic mesh from the existing mesh.
Creating a New Dynamic Mesh#
Adding triangles#
You can create a dynamic mesh from scratch, by adding one triangle after another. This variant is suitable for creating meshes with a moderate number of triangles. To create a new dynamic mesh you should do the following:
- Reserve a necessary space in a vertex buffer for triangle vertices and add indices for them to the index buffer. This is done by calling one of the following methods: All of these functions allocate memory for polygons of the corresponding form.
- Add the corresponding number of vertices via addVertex() method.
- After each call of the addVertex() function, you can set up properties of the last added vertex manually via calling: All these functions are optional, you can call them as needed.
- Calculate tangent vectors for all vertices via updateTangents().
- Calculate a bounding box and a bounding sphere for the created mesh by calling updateBounds().
- If necessary, you can remove duplicated vertices of the created mesh and optimize it for faster rendering. Use updateIndices() function, for example, if a quad polygon is created via addTriangles(2) (6 vertices are created) instead of an optimized addQuads(1) (4 vertices are created).
Usage Example#
The following example shows how to create a quad polygon by using the addTriangleQuads() function.
// AppWorldLogic.cpp
#include <UnigineObjects.h>
#include <UnigineEditor.h>
ObjectMeshDynamicPtr mesh;
int AppWorldLogic::init() {
// create a dynamic mesh and add it into the editor
mesh = ObjectMeshDynamic::create();
mesh->release();
Editor::get()->addNode(mesh->getNode());
mesh->setWorldTransform(translate(Vec3(0.0f, 0.0f, 2.0f)));
mesh->setMaterial("mesh_base", "*");
// allocate space in a vertex buffer and create vertex indices
mesh->addTriangleQuads(1);
// add vertices and assign texture coordinates, if necessary
mesh->addVertex(vec3(-1.0f, -1.0f, 0.0f));
mesh->addTexCoord(vec4(0, 0, 0, 0));
mesh->addVertex(vec3(1.0f, -1.0f, 0.0f));
mesh->addTexCoord(vec4(1, 0, 0, 0));
mesh->addVertex(vec3(1.0f, 1.0f, 0.0f));
mesh->addTexCoord(vec4(1, 1, 0, 0));
mesh->addVertex(vec3(-1.0f, 1.0f, 0.0f));
mesh->addTexCoord(vec4(0, 1, 0, 0));
// calculate tangent vectors
mesh->updateTangents();
// optimize vertex and index buffers, if necessary
//mesh->updateIndices();
// calculate a mesh bounding box
mesh->updateBounds();
Adding a Large Number of Vertices#
To create dynamic meshes with a huge number of vertices, it is better to use the more optimized approach: instead of allocating memory in small chunks (which can be costly), all necessary memory is preallocated first and filled with data after that.
- Allocate space for triangle vertices in an index buffer using allocateIndices().
- Allocate space for vertices in a vertex buffer using allocateVertex().
- Add the corresponding number of indices via addIndex() method.
- Follow steps 3-6 described above.
Usage Example#
mesh->release();
// allocate space in index and vertex buffers
mesh->allocateIndices(6);
mesh->allocateVertex(4);
// add vertices
// add indices for created vertices
mesh->addIndex(0);
mesh->addIndex(1);
mesh->addIndex(2);
mesh->addIndex(0);
mesh->addIndex(2);
mesh->addIndex(3);
Creating a Dynamic Mesh Based on the Existing Mesh#
- Create a new instance of the ObjectMeshDynamic class by passing the Mesh class instance as an argument to the constructor.
- Copy the mesh class instance to the existing ObjectMeshDynamic instance by passing the Mesh class instance as an argument to the setMesh() function.
Passing a Mesh to a New Dynamic Mesh#
Usage Example#
ObjectMeshDynamicPtr dynamic_mesh;
mesh->addBoxSurface("box", vec3(1.0f));
dynamic_mesh = ObjectMeshDynamic::create(mesh);
dynamic_mesh->release();
Editor::get()->addNode(dynamic_mesh->getNode());
// Assign a material
dynamic_mesh->setMaterial("mesh_base", "*");
Copy a Mesh to the Existing Dynamic Mesh#
Usage Example#
The following example shows how to copy the mesh from the Mesh instance to the ObjectMeshDynamic instance. It is supposed that you already have the Mesh instance, but in this example we create a new instance of the Mesh class with the box surface.
#include <UnigineConsole.h>
#include <UnigineCallback.h>
mesh->addBoxSurface("box", vec3(2.2f));
dynamic_mesh = ObjectMeshDynamic::create();
dynamic_mesh->setMesh(mesh);
Adding Physics to Dynamic Meshes#
To add some physical properties to the dynamic mesh so that it could participate in interactions between objects or external physical forces, it should have a body. You can easily assign it from the code or in the UnigineEditor.
Usage Example#
The following example shows how to add the rigid body with a shape to the dynamic mesh. In the example the dynamic mesh is created from the existing mesh with the box surface.
#include <UniginePhysics.h>
mesh->addBoxSurface("box", vec3(0.2f));
// create a new dynamic mesh from the Mesh instance and add it to editor
// assign a material to the dynamic mesh
dynamic_mesh->setWorldTransform(translate(Vec3(0.0f, 0.0f, 2.0f)));
BodyRigidPtr body = BodyRigid::create(dynamic_mesh->getObject());
ShapeBoxPtr shape = ShapeBox::create(body->getBody(), vec3(0.2f));
- The article about Physical bodies in Unigine.
- The article about Shapes in Unigine.
Intersections with Dynamic Meshes#
To detect if the dynamic mesh intersects a line or bounds of the specified volume, you should use one of the following functions:
- getIntersection() of the Object class that detects the intersection of the specified object with a tracing line. For example:
// note: the dynamic mesh has been created in the example above // create an ObjectIntersection instance to store intersection data ObjectIntersectionPtr intersection = ObjectIntersection::create(); // find an intersection if (mesh->getIntersection(vec3(0.0f), vec3(1.0f), intersection, 0)) Log::message("The dynamic mesh has been intersected by the line\n"); else Log::message("No intersections have been detected\n");
- getIntersection() functions of the World class that detect all the objects and nodes in the specific bounding volume or the first object intersection with the invisible tracing line. See examples of the world intersections.
- getIntersection() functions of the Physics class that detect intersections with a shape of bodies. If the object has no body, this function detects intersection with surfaces (polygons) of the object with the intersection flag. See usage example of the physics intersections here.
- getIntersection() of the Shape class detects the intersection of the specified shape with a tracing line. See the example of shape intersection here.
Saving a Dynamic Mesh to a File#
Usage Example#
dynamic_mesh->getMesh(mesh_0);
// save the mesh to the data/samples/dynamic_mesh.mesh file
mesh->save("unigine_project/meshes/dynamic_mesh.mesh");
